08-22-2017, 17:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-G981A Read Codes done Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G891A Selected port: COM76 SAMSUNG Mobile USB Serial Port Software version: 29.1 Checking Login and Password... OK Ballance: 30 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G891A Android version: 7.0 Product code: SM-G891AZAAATT Phone version: G891AUCU2BQB2 PDA version: G891AUCU2BQB2 CSC version: G891AATT2BQB2 CSC country code: USA CSC sales code: ATT HW version: REV0.5 Phone SN: R38J10MRR2E Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-02-01 RF cal date: 2017.01.24 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM49 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 28584828 NET lock: 61746303 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 |
The Following User Says Thank You to ghacks For This Useful Post: |
