10-20-2015, 11:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: SLK Age: 33
Member: 2291450 Status: Offline Sonork: typing... Thanks Meter: 1,600 | SM-J100H Unlock Without Root Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100H Software version: 23.1 Searching Samsung modem... detected COM94 Reading phone info... OK Model: SM-J100H Version: J100HXCU0AOD1/J100HSWR0AOD1/J100HXCU0AOD1/J100HXCU0AOD1 Product code: SM2J100HZWASWR Phone S/N: RV1G71R6C4N Imei: 353010071822573 Unique number: C0163DA546D62 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:48) Freeze code: 42083058 NET lock: 36150637 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.1 [/IMG] |
11-24-2015, 07:51 | #4 (permalink) |
Member: 2291450 Status: Offline Sonork: typing... Thanks Meter: 1,600 | Searching Samsung modem... detected COM5 Reading phone info... OK Model: SM-J100H Version: J100HXXU0AOF2/J100HOJV0AOF2/J100HXXU0AOF2/J100HXXU0AOF2 Product code: SM-J100HZWDKSA Phone S/N: R51G9023*** Imei: 3544670704***** Unique number: C012A678AA182 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:29) Freeze code: 25974053 NET lock: 15727252 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.4.1 |
03-15-2016, 05:35 | #6 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh
Member: 642363 Status: Offline Thanks Meter: 49 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100H Software version: 24.6 Searching Samsung modem... detected COM14 Reading phone info... OK Model: SM-J100H Version: J100HXXU0AOF2/J100HOJV0AOF2/J100HXXU0AOF2/J100HXXU0AOF2 Product code: SM-J100HZWDKSA Phone S/N: R51GA1NL42B Imei: 354467072664447 Unique number: CNJ009FA5B45792 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:27) Freeze code: 27075825 NET lock: 07371481 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.6 |
