Old 01-30-2016, 08:23   #1 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 66
SM-J120F FRP unlock error. Help me
I have samsung SM-J120F FRP locked. I want to unlock it via z3x box but it give me error. Please, help me
Searching Samsung USB Flash Interface... detected COM3
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... error
Done with Samsung Tool PRO v.24.1
Old 01-30-2016, 08:25   #2 (permalink)
Member: 1701137
Thanks Meter: 13
flash first then try again 100% ho ga
Old 01-30-2016, 14:39   #3 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 66
Ii flashed but doesn't works
Old 02-01-2016, 21:38   #4 (permalink)
Member: 1581092
Sonork: 100.1605440
Thanks Meter: 35
some problems, any solutions ???
Old 02-01-2016, 21:52   #5 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
PM me S/N of cell I may sent you 4files for same region, you can try to flash and then frp unlock
Old 02-27-2016, 18:39   #6 (permalink)
Member: 1870489
Sonork: 100.1663831
Thanks Meter: 483
J120F (SM-J120F)
Brand: SAMSUNG
IMEI: TAC: 355323 FAC: 07 SNR: 110094 CD: 2
S/N:R58H13HNGVF
Old 03-10-2016, 09:52   #7 (permalink)
Anamul.2014's Avatar
Member: 2145140
Sonork: 100.1650938
Thanks Meter: 90
SM-J120F Root File Need Plz Help me
Old 03-10-2016, 10:02   #8 (permalink)
scorpion_bashee's Avatar
Member: 334773
Thanks Meter: 92
just see the csc code and try to downgrade the build number then try to frp lock in z3x.
The Following User Says Thank You to scorpion_bashee For This Useful Post:
Old 05-22-2016, 00:35   #9 (permalink)
hafiz4saqib's Avatar
Member: 2289628
Thanks Meter: 226
I tried these below build version but problem is there same like as before " GOOGLE VERIFICATION ? "
1:- J120FXXU1AOL2_J120FOJV1AOL2_XSG = 14/12/2015
2:- J120FXXU1AOL3_J120FOJV1AOL3_KSA = 24/12/2015
3:- J120FXXU1APC3_J120FOJV1APC3_KSA = 07/04/2016
Even result is the same on SideSync method.
On Z3X-Box error is below,
Searching Samsung USB Flash Interface... detected COM18
Done with Samsung Tool PRO v.25.4.
In the last what should I do now ?
Old 08-11-2016, 14:47   #10 (permalink)
Member: 1450507
Sonork: 100.1603096
Thanks Meter: 49
How To Remove FRP Lock Samsung SM-J120F · HOME | Download Firmware File
Old 02-15-2018, 07:17   #11 (permalink)
Member: 2810903
amsung j120f CHECK FAIL. DEVICE 2 BINARY 1 Problem solved 100% tested
Page generated in 0.21815 seconds with 8 queries
