01-21-2017, 06:49 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: san fernando city la union
Member: 1028799 Status: Offline Thanks Meter: 49 | sm-j120zn unlocked Read codes only UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes Selected model: SM-J120ZN Software version: 27.7 Searching Samsung modem... detected COM50 Reading phone info... Ok Model: SM-J120ZN AP version: J120ZNDVU1APF9 CSC version: J120ZNTNX1APG2 CP version: J120ZNDVU1APG1 Product code: SM-J120ZZDNTNX Phone SN: R58HA03XD4J Unique number: CFN00700DDC7883 Reading IMEI... Ok IMEI: 357762070629476 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: AB B7 1E 68 E2 08 BB EB 4A EA 8F 72 DC D5 2F 48 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 84920938 NET lock: 15397248 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
06-16-2017, 07:44 | #2 (permalink) |
Junior Member Join Date: Mar 2007
Member: 473146 Status: Offline Thanks Meter: 1 | Samsung J120ZN unlock Operation: Read Codes Selected model: SM-J120ZN Software version: 28.2 Searching Samsung modem... detected COM154 Reading phone info... Ok Model: SM-J120ZN AP version: J120ZNDVU1AQB2 CSC version: J120ZNTLP1AQB1 CP version: J120ZNDVU1AQB1 Product code: SM-J120ZZKNTLP Phone SN: R58J51W56BR Unique number: CFN00344FF0B734 Reading IMEI... Ok IMEI: 35xxxxxxxxxxxxx (SIGN: OK) Checking hash file... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.2 It can't unlock this samsung j120ZN, please help. Thank you |
06-16-2017, 12:10 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
12-06-2017, 01:16 | #4 (permalink) |
Freak Poster Join Date: May 2010
Member: 1302063 Status: Offline Thanks Meter: 4 | followed the log but still can't unlock it. Waiting ADB device... OK Reading phone info... Model: SM-J120ZN Android version: 5.1.1 Product code: SM-J120ZZKNTLP Phone version: J120ZNDVU1AQB1 PDA version: J120ZNDVU1AQB2 CSC version: J120ZNTLP1AQB1 CSC country code: Australia CSC sales code: TLP HW version: MP 0.400 Phone SN: R58J92S0ZGP Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-02-01 RF cal date: 20170914 IMEI: 25159253xxxxxx Checking Super user right... false Root your phone manually and then repe Done with Samsung Tool PRO v.30.1 |
