07-26-2018, 21:47 | #1 (permalink) |
Freak Poster Join Date: Jun 2017
Member: 2730595 Status: Offline Thanks Meter: 13 | SM-J250G unlocking problem [Solved] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J250G Software version: 33.2 Checking Login and Password... OK Ballance: 70 crd. You have 70 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU2ARD3 CSC version: J250GOPP2ARD3 Phone version: J250GDXU2ARD3 Product code: SM-J250GZKAOPP CSC country code: Australia CSC sales code: OPP Phone SN: R28K30XHHSP IMEI: 354062090527864 HW version: MP0.900 RF cal date: 2018.03.06 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-04-01 Boot Warranty bit: 0 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM171 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (0) please update phone firmware Done with Samsung Tool PRO v.33.2 I HAVE DONE RE FLASHING PLS GIVE US A GOOD SOLUTION FOR THIS PROBEM |
08-03-2018, 00:17 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Nadi
Member: 210669 Status: Offline Thanks Meter: 97 | Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU2ARF2 CSC version: J250GVFJ2ARF2 Phone version: J250GDXU2ARF2 Product code: SM-J250GZKAVFJ CSC country code: Fiji CSC sales code: VFJ Phone SN: R28K22VJGJX IMEI: 354062090331556 HW version: MP0.900 RF cal date: 2018.02.28 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-06-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM30 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (0) please update phone firmware Done with Samsung Tool PRO v.33.5 with the same problem |
The Following User Says Thank You to kava For This Useful Post: |
08-09-2018, 12:40 | #5 (permalink) |
Junior Member Join Date: Sep 2009 Location: Macedonia , Prilep
Member: 1129818 Status: Offline Sonork: 100.1668462 Thanks Meter: 1 | Waiting for server answer... error (0) please update phone firmware Done with Samsung Tool PRO v.33.5 same problem to me, any solution? |
08-09-2018, 14:05 | #6 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,057 | Hi, wait for answer I will let you know solution for that issue, sorry for inconvinience.... Best Regards Z3X-Team |
The Following User Says Thank You to Z3X For This Useful Post: |
08-11-2018, 14:40 | #7 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Alex_Egypt
Member: 870868 Status: Offline Thanks Meter: 126 | me too same problem with J250Y it take 5 credit and give me wrong code that phone not accept it . |
The Following User Says Thank You to RazoR888 For This Useful Post: |
06-24-2019, 09:17 | #10 (permalink) |
Junior Member Join Date: Oct 2012 Location: Phnom Penh
Member: 1829284 Status: Offline Sonork: 1980 Thanks Meter: 1 | ndroid version: 7.1.1 PDA version: J250GDXU2ARF2 CSC version: J250GOPP2ARG1 Phone version: J250GDXU2ARF2 Product code: SM-J250GZKAOPP CSC country code: Australia CSC sales code: OPP Phone SN: R28K41AG0MZ IMEI: 354062090715972 HW version: MP0.900 RF cal date: 2018.04.13 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM4 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 28142035 NET lock: 40750393 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 |
05-05-2020, 09:54 | #11 (permalink) |
Major Poster Join Date: Mar 2014 Location: Gweru Zimbabwe
Member: 2147534 Status: Offline Thanks Meter: 13 | Still after updating firmware cant accept code Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU3ASK1 CSC version: J250GOLC3ASK1 Phone version: J250GDXU3ASG1 Product code: SM-J250GZKAXTC CSC country code: PHILIPPINES CSC sales code: XTC Phone SN: R28K51FNW5L IMEI: 355738090303088 HW version: MP0.900 RF cal date: 2018.05.16 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2019-10-01 Boot Warranty bit: 1 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM21 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 93085191 NET lock: 73809462 SUB lock: 13615073 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# If codes are not accepted, then flash latest firmware Done with Samsung Tool PRO v.39.9 |
