Old 12-28-2018, 19:01   #1 (permalink)
Member: 2588864
Thanks Meter: 21
SM-J260f frp 8.1.0?
please help me to remove FRP samsung J260F android 8.1.0 , jJ260FXXU1ARH7...... i try all solution posted on youtube and try use combination file but there is NO OEM to enable and also try combination way to enable adb but when flash the official firmware to remove by selecting j250f after flash phone hang on blocked by frp...........please need real solution do not just copy and past without being tested..........est regard to Z3X team
Old 12-29-2018, 06:14   #2 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 174
here is simple solution flash combination after that flash boot,sboot,system,recovery from latest stop phone will boot up and enter in menu go to setting enable oem,usb debuging do factory reset from menu frp will be gone make sure use latest stock room and combination
The Following User Says Thank You to Arslanmayo For This Useful Post:
Old 12-29-2018, 07:24   #3 (permalink)
Member: 2819079
Thanks Meter: 22
bro best method to remove frp is technocare apk install
The Following 2 Users Say Thank You to syedzameer$0004 For This Useful Post:
Old 12-29-2018, 13:49   #4 (permalink)
Member: 2588864
Thanks Meter: 21
thanks mr Arslanmayo but phone open and there is no OEM ....please any idea to solve this....thanks
Old 12-29-2018, 13:52   #5 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 262
Try this Note 9 FRP Bypass method without PC:
Might work on J260F too:
http://www.youtube.com/watch?v=OY7hmqRneY0
The Following User Says Thank You to Mobile-Lab For This Useful Post:
Old 12-29-2018, 15:15   #6 (permalink)
Member: 2588864
Thanks Meter: 21
thanks mr Mobile-Lab i already try this method but i failed to activated voice assist, there is no combination key to activated voice assistant, i need help i am now on phone and menue is open by i need guide to remove frp, i try every posted way but failed....please kindly any idea thanks in advance
Old 12-29-2018, 16:19   #7 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 262
There are 3 ways to activate Talkback on Samsung phones:
1. Press HOME button 3 times quickly
2. Quickly Press Volume up + Power key simultaneously (for newer phones)
3. Keep your two fingers on screen at Language Setup until talkback is enabled.
Old 12-29-2018, 17:42   #8 (permalink)
Member: 2588864
Thanks Meter: 21
thanks for all effort....it is now done by flashing proper combination file then flash same full flash without *user data* so after phone boot up go and enable developer and now oem is shown so make it on and make full factory reset.........now frp is off
best regard for all member trying support me Arslanmayo, Mobile-Lab
Old 01-11-2019, 16:06   #9 (permalink)
Unlocker_001's Avatar
Member: 614304
Thanks Meter: 100
not work for me i flash full combination after flash full stock without userdata and phone power on > select language > and need email ? any other solution ?
Old 01-11-2019, 20:25   #10 (permalink)
samicool88's Avatar
Member: 2085676
Thanks Meter: 67
bro after flash full combination then reset all in settings after flash only sboot, boot, recovry, and system
then on oem unlock and flash full
Old 01-12-2019, 14:44   #11 (permalink)
Member: 614304
Thanks Meter: 100
Not work ! I do all steps but in Developer not exist OEM Unlock !!!! Any other solution ?
Old 01-12-2019, 20:45   #12 (permalink)
samicool88's Avatar
Member: 2085676
Thanks Meter: 67
bro try 1st combination flash with odin tool
after do all
100% done
Old 01-14-2019, 16:10   #13 (permalink)
Member: 614304
Thanks Meter: 100
after do all
100% done
NOT WORK ! Flash combination by Odin - Do reset - flash sboot,boot,recovery, system from firmware - phone power on - enable developer options and there no OEM Unlock
Old 01-15-2019, 15:04   #14 (permalink)
Member: 1942851
oreo 8.1 not oem lock
Page generated in 0.18303 seconds with 7 queries
