10-15-2016, 22:07 | #1 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | SM-J320A FRP Removed, but still locked Step 1: Flashed Combination file Step 2: Ran Z3X FRP Reset Operation: Reset FRP Selected model: SM-J320A Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J320A Android version: 6.0.1 Product code: Phone version: PDA version: FA60_J320AUCU1APD1 CSC version: CSC country code: CSC sales code: HW version: Phone SN: R28H60XXXXX Modem board: RF cal date: IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Step 3: Factory Data Reset Step 4: Flash Factory Firmware FRP lock is still there. Any ideas? |
10-19-2016, 18:36 | #5 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | It seems like there are some issues with FRP removal on the J320 variants. After trying multiple times - flashing Combination file and resetting MSL and running FRP removal Z3X shows successful) and then Factory Reset, FRP is still on. I have tried downgrading to 26.8 and same problem. Has anyone had any success removing FRP on J320 - APD1 firmware? |
10-19-2016, 18:47 | #6 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478873 Status: Offline Thanks Meter: 51 | don't do frp through download mode. that way once z3x says its done. you can continue setting up the phone as if it never had frp on. once u get inside the phone do a factory reset. problem is, if you are flashing entire combination firmware it wont work, you need to flash sboot only, that will activate adb and z3x will be able to remove frp. I hope it helps, I was having same issue till I figured out what they were talking about "to hit continue on phone" |
10-19-2016, 21:22 | #7 (permalink) | |
Member: 2277857 Status: Offline Thanks Meter: 68 | Quote:
12-06-2016, 14:18 | #15 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1847057 Status: Offline Thanks Meter: 1 | Method I use on J320FN, may work similar on other variants: 0) Select Model J320FN in Z3x 1) Using Z3X flash 'COMBINATION_OXA_FA51_J320FNXXU0APD1_OXAFA51' 2) Reboot into 'Factory Binary' software to confirm flash 3) Select Model G925F in Z3x 4) REboot phone to download mode 5) Reset FRP lock in Z3x (as a G925F) 6) Check FRP is OFF in download mode 7) Reselect J320FN in Z3x 8) Flash 'STOCK_J320FN_XXU0APE6_DDX0APD1' 9) Done, check no FRP in setup screen |
The Following User Says Thank You to Lunch211 For This Useful Post: |
