Old 05-06-2017, 13:17   #31 (permalink)
Freeboy08's Avatar
Member: 1272267
Sonork: 100.1667652
Thanks Meter: 194
Searching Samsung modem... detected COM66
Reading phone info... OK
Model: SM-J320A
AP version: J320AUCU2APJ2
CSC version: J320AATT2APJ2
CP version: J320AUCU2APJ2
Product code: SM2J320AZACATT
Phone SN: R28J13KGAYL
Unique number: CQ3003D80AC9C14
Reading IMEI... OK
IMEI: 357173080164662 (SIGN: OK)
Checking hash file... OK
Reading data from phone... OK
Modem board: SHANNON308
HWID: B7 38 60 CC 6E D3 C4 8B 96 17 CC EF 9A F1 65 CA
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:06)
Freeze code: 73052027
NET lock: 13751691
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.28.1
Old 05-26-2017, 23:43   #32 (permalink)
myciviczc's Avatar
Member: 2260435
Thanks Meter: 111
Originally Posted by ritesh1 View Post
Operation: Read Codes
Selected model: SM-J320A
Software version: 27.7
Searching Samsung modem... detected COM605
Reading phone info... Ok
Model: SM-J320A
Product code: SM2J320AZABATT
Phone SN: R28HA1GD90W
Unique number: CQ300699EDECD73
Reading IMEI... Ok
IMEI: 357417072413102 (SIGN: OK)
Checking hash file... Ok
Reading data from phone... Ok
HWID: F6 A9 BE E4 6A 0B A0 AE 03 E4 09 3B 16 62 E8 5F
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:07)
Freeze code: 92496836
NET lock: 46947364
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.27.7
Please.. I need this 4file PJ2 firmware to unlock one of this phones
thanks
Old 06-06-2017, 13:16   #33 (permalink)
Member: 2385265
Thanks Meter: 12
Originally Posted by otrebla View Post
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button.
Software version: 26.3
Model: SM-J320A
AP Version: J320AUCU1APC4
CSC Version: J320AATT1APC4
CP Version: J320AUCU1APC4
Phone S/N: R28H32XS2FY
Imei: 35741707041xxxx
Unique number: CQ300EFC6D33223
HWID: 92 64 04 D2 39 5A AA 22 57 20 8F A4 DE B3 9D 2A
Please wait, calculating codes... OK (time - 00:00:08)
Freeze code: 95319197
NET lock: 09640594
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.26.3
Hello!
When you chose read code, on the z3x, which code will unlock the phone?the NET lock?
Thanks!
Old 06-08-2017, 01:09   #34 (permalink)
Member: 2450214
Thanks Meter: 93
Originally Posted by benaja View Post
Hello!
Thanks!
yes bro
thats the one
The Following User Says Thank You to lilshane For This Useful Post:
Old 06-09-2017, 17:45   #35 (permalink)
Member: 1867800
Sonork: postbit
Just read codes with normal security on 6.0.1 works fine!
Old 06-17-2017, 23:06   #36 (permalink)
Member: 1564613
I have the 28.1 version and I get same error on both "Read Codes" and "Unlock"
Operation: Unlock
Software version: 28.2
Searching Samsung modem... detected COM56
Model: SM-J320A
AP version: J320AUCU2AQC1
CSC version: J320AATT2AQC1
CP version: J320AUCU2AQC1
Phone SN: R28J11RJQXH
Unique number: CQ300D61EE48DC3
Reading IMEI... Ok
IMEI: 357417079438466 (SIGN: OK)
Reading data from phone... error (0)
Try downgrade modem if possible
Done with Samsung Tool PRO v.28.2
The Following User Says Thank You to estebangtz For This Useful Post:
Old 06-18-2017, 09:43   #37 (permalink)
Member: 90682
Thanks Meter: 20
Here is the solution for you:
Samsung J3 SM-J320A [Unlock Only](v6.0.1)(AQC1)
Go here to this link and download the CP Modem & use Odin - CP Flash it.
[This will downgrade your modem to CP version: J320AZTUU2APJ2]
SM-J320A 6.0.1 Stock Firmware Reqeust
Now use Z3X - Unlock - Read Codes:
Enjoy!
***Tested on my SM-J320A)(v6.0.1)(J320AUCU2AQC1)***
Here is the partial Z3X log:
Model: SM-J320A
CP version: J320AZTUU2APJ2 <===== Modem DG to PJ2
Product code: SM2J320AZWAATT
Phone SN: R28H80RVXXX
Unique number: CQ300DC9DD25873
Reading IMEI... Ok
Old 06-19-2017, 17:33   #38 (permalink)
Member: 30754
Thanks Meter: 9
not work when down grade for unlock baseband shown as unknown and box wont find port to unlock
Old 06-19-2017, 20:15   #39 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,076
You need to downgrade modem to this version: J320AUCU2APJ2
Tested and 100% working.......
Old 06-22-2017, 19:30   #40 (permalink)
Member: 30754
Thanks Meter: 9
nope
cause it not aqc1 when down grade no based BAND
this the build
J320aztus3aqd2
Old 06-23-2017, 10:27   #41 (permalink)
Member: 2575234
Thanks Meter: 1,076
nope
this the build
J320aztus3aqd2
Update your phone with Smart Switch or ask blang to upload J320aztus3aqd2 to support
After find root and unlock with new method. You can as well inbox me your imei. If clean, I will provide your unlock code.
Firmware for this phone is currently not free
Old 06-25-2017, 03:58   #42 (permalink)
Member: 2385265
Thanks Meter: 12
thanks for the reply! i have used the NET Lock code and it worked. now my j320A is unlocked.
Old 08-09-2017, 17:56   #43 (permalink)
Member: 369279
Sonork: STARPHONE
Thanks Meter: 20
for read codes j320a <3
easy way just choose j320az and read codes
The Following User Says Thank You to mide For This Useful Post:
Old 01-01-2018, 09:07   #44 (permalink)
Member: 2374540
Sonork: 100.1675955
Thanks Meter: 21
j320a unlocking problem solved 100%
j320a only change model j320az and then unlocke selected model ...
Old 01-08-2018, 20:00   #45 (permalink)
Member: 858854
Thanks Meter: 109
Selected model: SM-J320AZ
Software version: 29.2
Searching Samsung modem... detected COM81
Model: SM-J320A
Phone SN: R28H43JXZJK
Unique number: CQ3008BDFD23F43
Reading IMEI... OK
IMEI: 3xxxxxxxxxxxxxxxxx5 (SIGN: OK)
HWID: 34 90 3B F2 F4 98 7A E2 76 44 0E B0 6E FB D7 BA
Calculating... OK
Freeze code: 68508203
NET lock: 95917151
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.29.2
Thanx!!!
Page generated in 0.38157 seconds with 7 queries
