SM-J320AZ unlock done latest build UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J320AZ Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J320AZ Android version: 6.0.1 Product code: SM2J320AZWZAIO Phone version: J320AZTUS3AQG1 PDA version: J320AZTUS3AQG1 CSC version: J320AZAIO3AQG1 CSC country code: USA CSC sales code: AIO HW version: REV1.0 Phone SN: R28H521959B Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-07-01 RF cal date: 20160524 IMEI: 356519074519546 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: D2 EF 3F 52 80 40 DA 77 6E B7 9B A9 48 21 72 08 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 |
what root you use ?............. |
Here the unlock solution without root http://forum.gsmhosting.com/vbb/f453.../#post12669831 |
