Old 10-12-2017, 22:38   #1 (permalink)
Member: 2558211
Thanks Meter: 67
Arrow SM-J320AZ unlock done latest build
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J320AZ
Software version: 29.4
Waiting ADB device... OK
Reading phone info...
Model: SAMSUNG-SM-J320AZ
Android version: 6.0.1
Product code: SM2J320AZWZAIO
Phone version: J320AZTUS3AQG1
PDA version: J320AZTUS3AQG1
CSC version: J320AZAIO3AQG1
CSC country code: USA
CSC sales code: AIO
HW version: REV1.0
Phone SN: R28H521959B
Chip name: EXYNOS3475
Modem board: SHANNON308
Security patch: 2017-07-01
RF cal date: 20160524
IMEI: 356519074519546
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID: D2 EF 3F 52 80 40 DA 77 6E B7 9B A9 48 21 72 08
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.29.4
The Following User Says Thank You to MasterFpu$$y For This Useful Post:
Old 10-12-2017, 23:26   #2 (permalink)
Member: 399404
Thanks Meter: 29
what root you use ?.............
Old 10-12-2017, 23:31   #3 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 997
noo need root bro use eng modem google in this forum all are free
Old 10-13-2017, 04:20   #4 (permalink)
Member: 2395490
Thanks Meter: 464
Here the unlock solution without root
Samsung J320A New Security Unlock problem
The Following 2 Users Say Thank You to Alexandroid For This Useful Post:
Page generated in 0.21427 seconds with 7 queries
