06-22-2017, 17:42 | #4 (permalink) |
Junior Member Join Date: Oct 2013 Location: banglore
Member: 2050947 Status: Offline Sonork: 100.1648124 Thanks Meter: 81 | samsung j320f frp reset by z3x just select model j200g now connect your phone j320f(2016) in download mode click reset frp/react /ee.....done with z3x 10000000% working enjoyyy |
The Following 81 Users Say Thank You to manjunathjn For This Useful Post: |
06-29-2017, 10:49 | #6 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-J320F Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-J320F Android version: 5.1.1 Product code: SM-J320FZDDBNG Phone version: J320FDDU0APC3 PDA version: J320FDDU0APC4 CSC version: J320FODD0APC4 CSC country code: Bangladesh CSC sales code: BNG HW version: MP 0.400 Phone SN: R58H52T947B Chip name: SC9830I Modem board: SC9830i Security patch: 2016-04-02 RF cal date: 2016.05.17 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to salimsikder For This Useful Post: |
07-25-2017, 12:16 | #10 (permalink) |
Freak Poster Join Date: Jun 2007 Location: OUT OF CONTROL
Member: 536012 Status: Offline Sonork: 100.1660617 Thanks Meter: 120 | thanks...j200g trick works Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 28.8 Searching Samsung USB Flash interface... COM54 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.8 |
The Following 5 Users Say Thank You to xahin For This Useful Post: |
08-27-2017, 14:59 | #13 (permalink) |
Insane Poster Join Date: May 2011 Location: Inside Box
Member: 1580234 Status: Offline Thanks Meter: 47 | Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 27.9 Searching Samsung USB Flash interface... COM87 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.9 Thanks it works nicely.. |
The Following User Says Thank You to SantoshGhimire For This Useful Post: |
09-01-2017, 07:03 | #14 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: kottawa,sri lanka
Member: 1095235 Status: Offline Thanks Meter: 36 | Quote:
To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 29.1 Searching Samsung USB Flash interface... COM164 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' thanks | |
The Following 3 Users Say Thank You to roshan.mobile For This Useful Post: |
