Old 12-03-2016, 20:33   #1 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Sm-j320w8 latest patch security unlock done
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
To read security codes:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J320AZ
Software version: 27.3
Searching Samsung modem... detected COM149
Reading phone info... Ok
Model: SM-J320W8
AP version: J320W8VLU1APF2
CSC version: J320W8OYA1APF2
CP version: J320W8VLU1APF2
Product code: SM-J320WZAAXAC
Phone SN: R28HA2AKCEZ
Unique number: CQ3004536E40183
Reading IMEI... Ok
IMEI: 358998071641560 (SIGN: OK)
Reading data from phone... Ok
Unlocking... Ok
Rebooting phone... Ok
Unlock done
Done with Samsung Tool PRO v.27.3
Old 12-04-2016, 02:46   #2 (permalink)
TaiChi gossip's Avatar
Member: 2418095
Thanks Meter: 125
[ 2016/11/13 15:12:00 ] Searching Samsung modem... detected COM71
[ 2016/11/13 15:12:00 ] Reading phone info... ok
[ 2016/11/13 15:12:00 ] Model: SM-J320W8
[ 2016/11/13 15:12:00 ] AP version: J320W8VLS2APJ1
[ 2016/11/13 15:12:00 ] CSC version: J320W8OYA2APJ1
[ 2016/11/13 15:12:00 ] CP version: J320W8XXXXXXXX
[ 2016/11/13 15:12:00 ] Product code: SM-J320WZAARWC
[ 2016/11/13 15:12:00 ] Phone SN: R28H70GH6BP
[ 2016/11/13 15:12:00 ] Unique number: CQ3005FB76A1F63
[ 2016/11/13 15:12:00 ] Reading IMEI... ok
[ 2016/11/13 15:12:00 ] IMEI: 358998070353951 (SIGN: OK)
[ 2016/11/13 15:12:00 ] Reading data from phone... ok
[ 2016/11/13 15:12:00 ] Unlocking... ok
[ 2016/11/13 15:13:00 ] Rebooting phone... ok
[ 2016/11/13 15:13:00 ] Unlock done
Old 12-04-2016, 10:17   #3 (permalink)
Member: 1798740
Sonork: 1621776
Thanks Meter: 12
error on me october 1, 2016 patch level
Old 12-25-2016, 02:51   #4 (permalink)
Member: 723248
Thanks Meter: 7
j320w8 nv data error when unlock
How to patch explain any one
Old 12-30-2016, 12:11   #5 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 67
To unlock NEW security type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
To reset Google account activation lock:
4. Press 'Reset FRP' to deactivate Google account activation lock.
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
Operation: Read Codes
Selected model: SM-J320W8
Software version: 27.7
Searching Samsung modem... detected COM15
Model: SM-J320W8
CP version: J320W8VLS2APJ1
Phone SN: R28HC0PCL1Z
Unique number: CQ3008B9EF0DCB3
Reading IMEI... Ok
IMEI: 358998072341350 (SIGN: OK)
Checking hash file... Ok
Modem board: SHANNON308
HWID: DD DC 0D AA 55 EE 42 3B FA 27 CC B5 64 91 C9 D9
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 53131417
NET lock: 62625813
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.7
The Following 3 Users Say Thank You to .::Indian::. For This Useful Post:
Old 01-14-2017, 14:58   #6 (permalink)
Member: 2473356
Thanks Meter: 8
Model: SM-J320W8
Reading IMEI... Ok
Calculating... Ok
NET lock: 62625813
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
im using z3x and chimera and octop all gives me erro and i have same firm as yours
Old 01-14-2017, 16:33   #7 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
bro
try to reset msl after retry the processus or rooted this phone after make unlock..
Old 02-03-2017, 10:57   #8 (permalink)
Crazy Poster
Member: 1145569
Sonork: 373cbd71b5eb99f4e3001d009
Thanks Meter: 24
How to root j320w8
Bro how can i root it
Old 02-19-2017, 20:43   #9 (permalink)
Member: 1918024
Sonork: 100.1638888
Thanks Meter: 45
Operation: Unlock
Model: SM-J320W8
Reading IMEI... Ok
Unlocking... Ok
Unlock done
How to root the J320W8?
Old 02-19-2017, 22:59   #10 (permalink)
Member: 2339843
Thanks Meter: 1,450
Search google for root file...flash twrp recovery and install supersu..
Old 04-13-2017, 18:24   #11 (permalink)
Member: 2530835
I can't find one twrp working on j320w8.
Can anyone share twrp for j320w8 ?
Old 04-13-2017, 23:42   #12 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
read code no need to root buddy
Old 12-01-2017, 00:33   #13 (permalink)
Member: 686052
Root samsung sm-j320w8
Hi. I was reading your comments regarding rooting the above phone but i am confused.
Page generated in 0.26127 seconds with 8 queries
