02-14-2017, 10:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1913632 Status: Offline Thanks Meter: 233 | sm j321az unlocking help To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J321AZ Software version: 27.7 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SAMSUNG-SM-J321AZ Android version: 6.0.1 Product code: SM-J321AZDZAIO Phone version: J321AZTUU2APJ2 PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CSC country code: USA CSC sales code: AIO HW version: REV1.0 Phone SN: R28HA2W164L Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20161021 IMEI: Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.27.7 |
