Old 08-04-2018, 17:25   #1 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
SM-J327A Reset pattern lock?
I need to reset pattern lock on this device j327aucs2arg2, but OI don't see the option in Z3X software. Is it still possible using eng boot and adb command?
Old 08-04-2018, 21:14   #2 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
Is there a combination with binary 2 and Rev 2 available? Even if it is for purchase I don't mind.
Old 08-05-2018, 04:42   #3 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,041
in shell z3x it free bro enjoy download
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 08-05-2018, 05:32   #4 (permalink)
Member: 2802156
Thanks Meter: 121
phones that ship with 7.0 or later like this model will not accept eng boot on it's own
you can try flashing all eng files EXCEPT - system, boot, recovery, cache to try and not lose data
system-boot must match otherwise phone won't boot up
Old 08-08-2018, 00:20   #5 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
I can't see a combination j327Axxxx2xxx2 in shell. I need to activate adb to reset lock pattern via adb without losing data.
Old 08-08-2018, 00:24   #6 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
I flashed eng-boot with same binary but different revision (last number) and did not work. I was able to bring it back to life by flashing a stock boot with binary 2 and rev 2. That is why I want to try with eng boot with binary2 and rev2 but can't find it.
Old 08-08-2018, 01:48   #7 (permalink)
Member: 2590666
Thanks Meter: 8
Check here this may help you
https://easy-firmware.com/index.php?...older&id=24848
Old 08-08-2018, 04:01   #8 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,041
it in support why not look at RA1 combin and download it
Old 08-08-2018, 06:06   #9 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
RA1 no good... Phone does not boot with that one. I need eng boot RD2 or anything with a 2 for binary and revision also.
Old 08-08-2018, 06:09   #10 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
Originally Posted by yonic69 View Post
Thanks I already have all those but none work. I need bin 2 and rev 2...
Old 08-08-2018, 06:14   #11 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,041
thanks i already have all those but none work. I need bin 2 and rev 2...
give me ur teamviwer id and u have z3x? IF YES I WILL HELP U
Old 08-08-2018, 14:48   #12 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
Yes I have Z3x... My problem is that I cant lose data. I extracted boot from those combination files and repacked as md5 they all flash ok but since system is bin2 and rev2 the phone does not boot. I can make it boot perfectly by flashing bin2 with RD2 stock boot. So I figured that by using a boot from a combination that also has bin2 AND rev2 will work and boot the phone with adb enabled. Both numbers need to be "2"... Thats my theory since it booted fine again with stock boot with both numbers on 2.
Old 08-08-2018, 15:51   #13 (permalink)
Member: 2711124
Thanks Meter: 34
What you mean is that you need to keep the data to remove the screen lock password. You can't boot from the boot file of the project file J327AUCU2ARA1, you can boot with the boot phone of J327AUCS2ARD2. Does the mobile phone FRP and OEM are off?
Old 08-08-2018, 20:17   #14 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
Yes I can boot with 2ARD2 and yes oem and frp are off... It also accepts 2arc1 combination sboot.
Old 08-09-2018, 15:59   #15 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 106
Since stock 2ARD2 boot works to make the phone boot, I guess I'll have to wait and see if a combination with 2xxx2 comes out and test with that boot. I guess they are checking for binary number and rev number to match the firmware on the phone. Just my theory I'm no expert LOL.
Page generated in 0.38408 seconds with 8 queries
