Old 02-28-2017, 17:56   #1 (permalink)
Member: 2529251
Thanks Meter: 275
SM-J327p unlock with files 100%
J327P UNLOCK WITH FILES
Please flash the combination
Use z3x to unlock using model J320P
Then flash back stock firmware .
See links below.
If you have any problem PM me.
Thanks to my team @darmiles :-)
CSC https://files.fm/u/sb887fep
AP https://files.fm/u/vzjdm7dc
BL https://mega.nz/#!C5B1xaya!m-15LNYzq...tsIkbH22cXlvgU
CP https://mega.nz/#!HoZV3RiD!5pg_LxdF3...Gvndbg7TeFg8q4
COMBINATION
https://mega.nz/#!C1YSBJ5D!DVVXsvXIy...iz_92mSA0im8jk
The Following 56 Users Say Thank You to cyc0d3d For This Useful Post:
Old 03-01-2017, 22:59   #2 (permalink)
Member: 2529251
Thanks Meter: 275
Guys please post sucess after unlock. I only test with z3x input is appreciated
Sent from my SM-G930F using Tapatalk
The Following User Says Thank You to cyc0d3d For This Useful Post:
Old 03-03-2017, 12:27   #3 (permalink)
Member: 1908148
Sonork: jose
Thanks Meter: 2
THANKS it works fine for me 100%
The Following 2 Users Say Thank You to ssj4lvu For This Useful Post:
Old 03-04-2017, 20:22   #4 (permalink)
Member: 2112980
Thanks Meter: 2
your method work perfect...
Thank you very much for your help...
The Following User Says Thank You to dejama979 For This Useful Post:
Old 03-06-2017, 04:40   #5 (permalink)
Member: 239430
Smile j327p unlock
thank you sir it works for me 100% tested in 4 units
Old 03-07-2017, 23:38   #6 (permalink)
Member: 439031
Thanks Meter: 23
tks al 100 flash z3 and unlock...
Old 03-08-2017, 20:19   #7 (permalink)
Member: 2529251
Thanks Meter: 275
Thank you for your input guys.
Has any one tried to unlock with octopus or gcpro ?
Old 03-09-2017, 01:26   #8 (permalink)
Member: 1850573
Thanks Meter: 3
thanks works 100%%% with Z3X. try it with GCPRO and did not work
Old 03-13-2017, 02:36   #9 (permalink)
Member: 2422331
Thanks Meter: 41
After flash and do unlock its require root
Operation: Unlock
Selected model: SM-J327P
Software version: 27.8
Waiting ADB device...
Please, allow USB debugging on phone... Ok
Reading phone info...
Model: SM-J327P
Android version: 6.0.1
Product code: Not Active
Phone version: J327PVPU1APL1
PDA version: J327PVPU1APL1
CSC version: J327PSPT1APL1
CSC country code: USA
CSC sales code: BST
HW version: J327P.03
Phone SN: 00000000000
Modem board: MSM8917
RF cal date: 2016.12.15
IMEI:
Writing AT RIL... Ok
Initialization AT RIL... root required
Checking Super user right... false
Super user right required true
Done with Samsung Tool PRO v.27.8
The Following User Says Thank You to ChElEuLaVi For This Useful Post:
Old 03-13-2017, 02:40   #10 (permalink)
Member: 2529251
Thanks Meter: 275
The new 27.8 update now supported model j327p on z3x but if you read it is still in test mode.
Samsung Tool PRO 27.8 Update.
Added:
- support SM-J327P (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Write CERT, Unlock(TEST))
Please use my method mentioned above it will not ask for root if you flash the combination file and unlock with model j320p.
I have not tested the new software but will do so next week Wednesday as i have 120 pieces to unlock.
I will try to unlock using j327p with combination. Until then use the method above
The Following 3 Users Say Thank You to cyc0d3d For This Useful Post:
Old 03-13-2017, 03:23   #11 (permalink)
Member: 2422331
Thanks Meter: 41
Added:
thanks I try previous version Its works
The Following 2 Users Say Thank You to ChElEuLaVi For This Useful Post:
Old 03-13-2017, 03:24   #12 (permalink)
Member: 2422331
Thanks Meter: 41
Added:
Old 03-14-2017, 21:06   #13 (permalink)
Member: 2644451
Sonork: 1675850:alex_foxcel
se podrá usar este método en octoplus con el archivo de combinacion
Old 03-15-2017, 06:10   #14 (permalink)
Member: 2395490
Thanks Meter: 515
No bro. Probado. Solo sale con Z3X. Hasta ahora
The Following 3 Users Say Thank You to Alexandroid For This Useful Post:
Old 03-15-2017, 06:18   #15 (permalink)
Member: 2017594
Thanks Meter: 8
thank you sir it works for me 100% tested.....
The Following 4 Users Say Thank You to cassnicole For This Useful Post:
Page generated in 0.20655 seconds with 8 queries
