12-13-2017, 09:52 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: Meetiyagoda
Member: 504925 Status: Offline Thanks Meter: 55 | sm-j330f unlock done Z3X read codes via server [UPLOAD] Selected model: SM-J330F Software version: 30.1 Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J330F Android version: 7.0 Product code: SM-J330FZKDNEE Phone version: J330FXXU1AQF7 PDA version: J330FXXU1AQF9 CSC version: J330FNEE1AQF2 CSC country code: Nordic CSC sales code: NEE HW version: MP 0.400 Phone SN: R58J82ENGLM Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20170810 IMEI: 3588700835***** Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM14 detected Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 84182859 NET lock: 63953830 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
The Following User Says Thank You to kalumetech For This Useful Post: |
07-10-2018, 07:11 | #2 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2667722 Status: Offline Thanks Meter: 3 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever ('Diag' algo): Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever ('Upload' algo): Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J330F Software version: 33.2 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330F Android version: 7.0 PDA version: J330FXXU3ARA3 CSC version: J330FDBT3ARA1 Phone version: J330FXXU3ARA4 Product code: SM-J330FZDDDBT CSC country code: Germany CSC sales code: DBT Phone SN: R58K43M9B0M IMEI: 356075097232104 HW version: MP 0.500 RF cal date: 20180420 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-01-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Initialization zTool... error (0.8) Done with Samsung Tool PRO v.33.2 |
