04-25-2019, 11:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | SM-J410f after combination, no download mode ! i got a j410f hang on logo, i hard reset it manualy by botton, the phone has powered on normaly with frp, so i flashed it with combination file fromp z3x support, and try to reset frp with no luck because of the oem disabled, i usuly flash system, boot, recovery without userdata from a full flash after the combination, to make oem apear, i did it this time with this phone, then the phone remain start in samsung logo, then recovery menu aprer for one second, then the phone power off, now i can't enter download mode with vol+ +vol - + usb to pc, and i can't withotg too ! any idea how to make it enter to download mode again ? thanks |
04-26-2019, 10:00 | #2 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: searching Age: 31
Member: 2424314 Status: Offline Thanks Meter: 731 | Quote:
The Following User Says Thank You to farooquepm For This Useful Post: |
06-22-2019, 13:00 | #9 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Pakistan. D.I.Khan
Member: 1190993 Status: Offline Sonork: 100.1622640 Thanks Meter: 72 | I have also same to same problem I flashed J410f without userdata and cashe partition .after flash set totaly dead.but when press power and volume down button as same time 10 second.set show logo and goes to dead please expert give me any good idea |
The Following User Says Thank You to asim_3399 For This Useful Post: |
07-21-2019, 10:23 | #11 (permalink) |
Freak Poster Join Date: Jul 2014 Location: pakistan Age: 35
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | did someone have solution for j410f cant put in download mode....after write combinaton and flash file with out...cache+user date+meta phone was suck when try to put in download mode shows recovery menu and then restart...any solutoin |
07-21-2019, 14:11 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | only solution use usb cable with jig not classic jig its a usb cable with jig resistance and use this cable to flash phone |
07-21-2019, 17:35 | #14 (permalink) |
Freak Poster Join Date: Mar 2016 Location: gsm would
Member: 2550445 Status: Offline Thanks Meter: 26 | if you flash combination aftar open, you can use z3x rebot to flash batton.......... [QUOTE=.:bono:.;13633681]hi all, i got a j410f hang on logo, i hard reset it manualy by botton, the phone has powered on normaly with frp, so i flashed it with combination file fromp z3x support, and try to reset frp with no luck because of the oem disabled, i usuly flash system, boot, recovery without userdata from a full flash after the combination, to make oem apear, i did it this time with this phone, then the phone remain start in samsung logo, then recovery menu aprer for one second, then the phone power off, now i can't enter download mode with vol+ +vol - + usb to pc, and i can't withotg too ! any idea how to make it enter to download mode again ? if you flash combination after open, you can use z3x reboot to flash batton.. me the same problem before .........,,................ .................................. |
The Following 2 Users Say Thank You to mrmmethun555 For This Useful Post: |
