03-04-2017, 13:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2016 Location: Lahore
Member: 2595115 Status: Offline Thanks Meter: 54 | SM-J510F imei repair & no network! Brand:- SAMSUNG Model:- SM-J510F CPU:- MSM8916 Problem:- IMEI Status:_Fail, Emergency Calls Only, and Z3X not supported Write Cert and Patch Cert of this model SM-J510F. Please give me Idea how to solve this problem.? I want Repair ImeI and Repair Network. Thanx in Advance.. Last edited by zain_gsm; 03-04-2017 at 13:13. Reason: Sanp-Shoot Link Update.. |
03-24-2018, 14:03 | #9 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write QCN Selected model: SM-G910S Selected port: COM34 SAMSUNG Mobile USB Serial Port Software version: 30.9 Reading QCN file... OK Reading ID... OK Detected ID: 00000FFE (MSM8916) SW version: MPSS.DPM.2.0.2.c1.7-00036-M8936FAAAANUZM-1.47933.1.82029.1 Checking paths... OK Restoring EFS backup... OK Restoring NV items... OK Restoring NV item SIM1... OK Restoring NV item SIM2... OK Restoring Provisioning Item Files... OK Restore QCN done Done with Samsung Tool PRO v.30.9 |
