Old 10-23-2017, 14:41   #1 (permalink)
Member: 45770
Thanks Meter: 29
sm-j530f No sound after root..
I tried different software, and I tried 2 root files >> 1-SM-J530F_cf_ar_Z3X-TEAM.tar 2- CF-Auto-Root-j5y17lte-j5y17ltexx-smj530f.tar.md5
but same problem.... No sound after root....
note: I am installing software and factory reset sound come back to again
Old 10-23-2017, 17:35   #2 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,806
u tried
http://forum.gsmhosting.com/vbb/12638855-post2.html
Old 10-24-2017, 10:02   #3 (permalink)
Member: 45770
Thanks Meter: 29
Originally Posted by profkefah View Post
Brother Do not read what I write... i tried this file.. same problem...
Old 10-24-2017, 10:19   #4 (permalink)
Member: 2717040
Thanks Meter: 32
change modem file or flash latest firmware.
Old 10-24-2017, 10:33   #5 (permalink)
Feiselski's Avatar
Member: 2583091
Thanks Meter: 413
Use TWRP and Supersu to root instead of CF Root
TWRP recovery available here for J530
https://forum.xda-developers.com/gal...-2017-t3668266
Old 10-24-2017, 11:44   #6 (permalink)
Member: 45770
Thanks Meter: 29
twrp already tried.. latest firmware tried and different firmware tried.....2 root files tried (2.82 and 2.79 sr3)... but some problem...
how to solve... please help...
Old 10-24-2017, 12:58   #7 (permalink)
Crazy Poster
Member: 2026694
Thanks Meter: 4
u tried combination
https://www.4shared.com/archive/z88t...530FXXU1.html?
Old 10-24-2017, 16:16   #8 (permalink)
Member: 45770
Thanks Meter: 29
Originally Posted by yosef-ali000 View Post
dear bro; my problem, no sound after root.... i installing new firmware again come back sound...
i want to root phone and I want your sound to work....
Old 10-24-2017, 23:24   #9 (permalink)
Member: 45770
Thanks Meter: 29
Dear Friends Problem Solved...
I did a hard reset 3-4 times. Likewise the root was loaded 3-4 times and the problem was solved by itself.
Old 11-07-2017, 16:19   #10 (permalink)
Member: 1905998
No sound after root
Good day,
Would you please confirm that sound issue after root is solved by doing it several times?
The Following User Says Thank You to Cray81 For This Useful Post:
Old 11-08-2017, 19:20   #11 (permalink)
Member: 45770
Thanks Meter: 29
Originally Posted by Cray81 View Post
Good day,
yes bro i confirm... problem solved.. first, root and hard reset and again root problem not solved is again hard reset and after again root... success....
The Following User Says Thank You to selammi For This Useful Post:
Old 11-14-2017, 10:33   #12 (permalink)
Member: 1905998
Brother, thank you for quick reply.
Would you please give us detailed information on tools that you have used to succeed with J530f/fn root.
Old 12-23-2017, 09:46   #13 (permalink)
Member: 1706168
Sonork: 100.1619095
Thanks Meter: 66
tried many times hard reset via recovery, reflashing but still no sound
Old 12-24-2017, 06:39   #14 (permalink)
Member: 1706168
Sonork: 100.1619095
Thanks Meter: 66
can you please give more details, when to hard reset , after reset or let the device should turn on then hard reset with recovery?
Old 01-29-2018, 17:38   #15 (permalink)
Member: 120235
Thanks Meter: 11
I have same problem, when root with SM-J530F_cf_ar_Z3X-TEAM.tar and CF-Auto-Root-j5y17lte-j5y17ltexx-smj530f.tar.md5 no sound and imei repair ok. But when factory reset, imei ok but no signal and no sound.
When factory reset and re root device reset screen appear. Resetting and root again phone working new imei but no signal, i m patching cert ang signal ok but when unroot no signal again. Now phone working only root and new imei.
I wait working perfect root file. Because i m caused 1 phone with this root files.
Page generated in 0.23342 seconds with 8 queries
