06-27-2019, 10:43 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 39
Member: 681346 Status: Offline Thanks Meter: 14 | sm j530l emergency call only [Answered] Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Read EFS Selected model: SM-J530L Software version: 36.2 Waiting ADB device... OK Reading phone info... Model: SM-J530L Android version: 8.1.0 PDA version: J530LKLU3BSC2 CSC version: J530LLUC3BSC2 Phone version: J530LKLU3BSC1 Product code: CSC country code: KOREA CSC sales code: LUC Phone SN: RF9JA00964 IMEI: 357668081191309 HW version: REV0.5B RF cal date: 20171003 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-03-01 Boot Warranty bit: 1 Checking Super user right... false This model not supported for auto root Done with Samsung Tool PRO v.36.2 |
07-01-2019, 10:39 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
