10-04-2019, 12:34 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: KSA
Member: 1813906 Status: Offline Sonork: 100.1618216 Thanks Meter: 33 | SM-J600G Custom Binary blocked by OEM Lock i flashed with the same U4 binary latest ver and same u4 combination file but result same no enter recovery only download mode try all files. |
10-04-2019, 15:37 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hello, when you did the flash with the combination u4 for j600g, were you able to install it on the phone or did you get an error message on the phone display or did it stay on bootloop on the samsung logo? In practice, if the combination was able to install it correctly on the phone without any error, you should enter the factory binary mode select setting and the developer option from the combination and enable the oem unlock, done via z3x do the frp reset via adb selecting a other model type j700f and reset the frp because the j600g model is not supported, make a factory reset with the phone started install the stock firmware in 4 file | |
