06-09-2016, 07:15 | #2 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: kpk Pakistan
Member: 1985156 Status: Offline Sonork: 100.1652265 Thanks Meter: 313 | Quote: | |
06-09-2016, 16:43 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: kalimatan selatan - indonesia
Member: 259306 Status: Offline Thanks Meter: 96 | Quote:
flash with odin3 v1.85 or Odin3 v3.09 ? in select on PDA or bootloader ? | |
06-09-2016, 18:04 | #10 (permalink) | |
i downgrade z3x to v24.6 problem same........ UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700F/DS Software version: 24.6 Searching Samsung USB Flash Interface... detected COM6 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.6 | |
10-02-2016, 15:26 | #15 (permalink) |
Freak Poster Join Date: Jan 2013 Location: INDIA ANDHRAPRADESH Age: 32
Member: 1873923 Status: Offline Thanks Meter: 41 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-J700F Software version: 26.8 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 5.1.1 Product code: SM-J700FZDDINS Phone version: J700FXXU2APC1 PDA version: FA51_J700FXXU2APC1 CSC version: CSC country code: CSC sales code: HW version: MP 0.701 Phone SN: RZ8H20XZP8B Modem board: SHANNON310 RF cal date: 20160219 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.26.8 |
