10-30-2017, 20:49 | #1 (permalink) |
Insane Poster Join Date: Dec 2013
Member: 2077877 Status: Offline Thanks Meter: 1 | SM-J700T1 7.1.1 FRP remove how to [Solved] |
10-30-2017, 20:53 | #2 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
The you can use your eng boot. Downgrade is possible, but to QF1. | |
The Following User Says Thank You to Alexandroid For This Useful Post: |
10-30-2017, 22:33 | #3 (permalink) |
Freak Poster Join Date: Aug 2007 Location: dubai
Member: 564909 Status: Offline Sonork: 1594465 Thanks Meter: 37 | download combination file select only boot.cach.recovery only your adb is enable remove frp via adb then flash stock again 10000000% confirm solution ihave done many phone if any phone no option frp then do same select same chip other model and do frp 1000% success enjoy |
02-17-2018, 10:49 | #4 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
04-16-2018, 07:46 | #5 (permalink) |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | J700T1 FRP Bypass: if you're on 7.1.1 already, downgrade to QF1 version first. Then combination file (QC1) flash only boot, recovery & cache. Phone will restart normally with ADB Enabled. |
The Following 3 Users Say Thank You to himig_natin For This Useful Post: |
04-25-2018, 01:31 | #6 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1632035 Status: Offline Sonork: DW Thanks Meter: 2 | I like to make it as easy as possible... Was on QK3 (7.1.1) Flashed full combi file QC1 Reset FRP Reboot to Download and flash full QK3 Reset in Settings to finish after it reboots and rebuilds cache. No need to downgrade with full 6.0.1 then use the boot and recovery from combi. unless you want to just stay on Marshmallow for some reason. |
05-29-2018, 17:39 | #7 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Quote:
it worked 100% QK3 it worked 100% 1- downgrade to QF1 2- pass this boot to activate the ADB in ap with odin https://www.4shared.com/archive/E-I37P-zfi/boot.html 3-FRP WITH Z3X Operation: Reset FRP Selected model: SM-J700T1 Software version: 32.4 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-J700T1 Android version: 6.0.1 PDA version: J700T1UVS3AQF1 CSC version: J700T1TMK3AQF1 Phone version: J700T1UVS3AQF1 Product code: SM2J700TZWATMK CSC country code: USA CSC sales code: TMK Phone SN: R58H8574A0L IMEI: 35721xxxxxxxxxx HW version: REV0.5 RF cal date: 20160831 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 Boot Warranty bit: 0 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.32.4 | |
The Following 5 Users Say Thank You to chipscell25 For This Useful Post: |
06-04-2018, 21:53 | #8 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Operation: Reset FRP Selected model: SM-J700T1 Software version: 28.6 You must activate ADB before reset FRP Sim Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Sim Waiting ADB device... OK Obtendo informações do celular... Modelo: SM-J700T1 Android version: 6.0.1 Código do Produto: SM2J700TZWATMK Versão do Celular: J700T1UVS3AQF1 PDA version: J700T1UVS3AQF1 CSC version: J700T1TMK3AQF1 CSC country code: USA CSC sales code: TMK HW version: REV0.5 Phone SN: R58H4342NQP Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160420 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.6 |
