12-20-2018, 19:20 | #31 (permalink) |
Freak Poster Join Date: Aug 2010 Location: iran
Member: 1368525 Status: Offline Thanks Meter: 23 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Patch Certificate Selected model: SM-J701F Software version: 34.5 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 8.1.0 PDA version: J701FDDU6BRI1 CSC version: J701FODD6BRI1 Phone version: J701FXXU6BRH5 Product code: SM-J701FZKDINS CSC country code: India CSC sales code: INS Phone SN: RF8J82ZMQPZ IMEI: 355006009588490 HW version: MP 0.400 RF cal date: 20170824 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-09-01 Boot Warranty bit: 1 SIM State: READY,ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.34.5 ---------------------------------------------------------------------------------- patch ok but emergency call only |
12-21-2018, 03:18 | #32 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2883149 Status: Offline Thanks Meter: 11 | At This Time SM-J701F 8.1.0 u6 Only Possible To Back Origianl IMEI 1. 1st Flash U6 Combination 2. OPEN BST Select J700H 3. Make Click Default Efs. 4. if Security Not Damaged Org imei Back. 5. Now Flash Only Boot, Recovery, & System From Stock. |
The Following 9 Users Say Thank You to NeedFlashFile For This Useful Post: |
04-20-2019, 13:20 | #39 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Quote:
06-18-2019, 06:50 | #42 (permalink) |
Junior Member Join Date: Oct 2007
Member: 615565 Status: Offline Thanks Meter: 0 | plz help z3x team J701F 8.1.0 u6 (Oreo) IMEI Repair Solution Needed! REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-J701F Software version: 34.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 8.1.0 PDA version: J701FDDU6BRI1 CSC version: Phone version: J701FXXU6ARH1 Product code: SM-J701FZKD CSC country code: CSC sales code: Phone SN: 00000000000 IMEI: HW version: MP 0.400 RF cal date: 20180104 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1) Initialization zTool... error (0 1) Try downgrade modem if possible Done with Samsung Tool PRO v.34.1 plz help z3x team :-( |
08-29-2019, 12:29 | #45 (permalink) |
Insane Poster Join Date: Dec 2013 Location: Swat Pakistan Age: 41
Member: 2089757 Status: Offline Thanks Meter: 8 | easy method for j701f u6 rooting https://www.youtube.com/watch?v=1iwRFOkLYLk |
The Following User Says Thank You to swat2 For This Useful Post: |
