12-06-2016, 11:53 | #1 (permalink) | ||
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | SM-J710F Network Problem IMEI Write Success Patch Certificate Success SIM Work Fine But Problem Is When Iam Trying To Re flash Or Doing Hard Reset Signal Gone And Emergency Call Only Appear Also iam Trying To Write Cert File But Not Success Here Is Logs Quote:
12-06-2016, 13:00 | #3 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | patch cert will be losed after you will do hard reset. imei similar like on sticker? |
The Following User Says Thank You to blang For This Useful Post: |
12-06-2016, 15:33 | #8 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | I FACED SAME PROBLEM WITH SAMSUNG S3 IT HAD CUSTOM ROM AND IMEI 0049 SO I REPAIRED IMEI AND DID PATCH CERT EVERYTHING OK BUT ONCE FLASHING OR HARD RESET IMEI NULL SO ITS APPEAR j710f PATCH CERT HAS SAME PROBLEM |
The Following User Says Thank You to profkefah For This Useful Post: |
12-07-2016, 15:30 | #12 (permalink) |
No Life Poster Join Date: Dec 2014 Location: 1
Member: 2314755 Status: Offline Thanks Meter: 84 | pacth cert its not solution for permanent , everytime you do hard reset o reflash will gone。its normal 。。starting from s3 eyxnos |
The Following User Says Thank You to carlos_zyk For This Useful Post: |
12-08-2016, 06:26 | #13 (permalink) |
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | J710F Still Same Here I Need Permanent Solution This Type Of Problems |
The Following User Says Thank You to ::SYED MOBILE:: For This Useful Post: |
12-08-2016, 12:22 | #14 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1378050 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Operation: Write CERT Selected model: SM-J710F Software version: 27.4.2 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKUSER Phone version: J710FXXU1APCB PDA version: J710FXXU1APCB CSC version: J710FOXY1APCB CSC country code: Russia CSC sales code: SER HW version: MP 0.300 Phone SN: RZ8H91WX40X Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: 20160928 IMEI: Checking Super user right... true Card error (32012) Done with Samsung Tool PRO v.27.4.2 |
The Following User Says Thank You to editormeet For This Useful Post: |
12-09-2016, 14:37 | #15 (permalink) |
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | J710F Still have In My Hand & Also Waiting For Good Response From Z3X Team |
