01-25-2019, 06:31 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J320P Software version: 34.8 Waiting ADB device... OK Reading phone info... Model: SM-J320P Android version: 5.1.1 PDA version: J320PVPU1APH2 CSC version: J320PSPT1APH2 Phone version: J320PVPU1APH2 Product code: Not Active CSC country code: USA CSC sales code: XAS Phone SN: 00000000000 IMEI: HW version: J320P.02 RF cal date: 2016.11.03 Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-08-01 Boot Warranty bit: 0 Writing AT RIL... OK Initialization AT RIL... OK Unlocking... error Done with Samsung Tool PRO v.34.8 |
