01-21-2017, 20:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-J710FN Unlock done by read codes [ 1/13/2017 12:53:00 PM ] Selected model: SM-J710FN [ 1/13/2017 12:53:00 PM ] Software version: 27.7 [ 1/13/2017 12:53:00 PM ] [ 1/13/2017 12:53:00 PM ] Searching Samsung modem... detected COM231 [ 1/13/2017 12:53:00 PM ] Reading phone info... OK [ 1/13/2017 12:53:00 PM ] Model: SM-J710FN [ 1/13/2017 12:53:00 PM ] AP version: J710FXXU2APL8 [ 1/13/2017 12:53:00 PM ] CSC version: J710FITV2APK1 [ 1/13/2017 12:53:00 PM ] CP version: J710FXXU2APK2 [ 1/13/2017 12:53:00 PM ] Product code: SM-J710FZWNITV [ 1/13/2017 12:53:00 PM ] Phone SN: RF8HB3RT37Z [ 1/13/2017 12:53:00 PM ] Unique number: CAJ03E59F5F80A3 [ 1/13/2017 12:53:00 PM ] Reading IMEI... OK [ 1/13/2017 12:53:00 PM ] IMEI: 35xxxxxxxxx (SIGN: OK) [ 1/13/2017 12:53:00 PM ] Checking hash file... OK [ 1/13/2017 12:53:00 PM ] Reading data from phone... OK [ 1/13/2017 12:53:00 PM ] Modem board: SHANNON315 [ 1/13/2017 12:53:00 PM ] HWID: 37 07 00 00 00 00 00 00 00 00 00 00 BE 98 51 60 [ 1/13/2017 12:53:00 PM ] Reading NV data... OK [ 1/13/2017 12:55:00 PM ] Checking NV data... OK [ 1/13/2017 12:55:00 PM ] Calculating... OK [ 1/13/2017 12:55:00 PM ] Please wait, calculating codes... OK (time - 00:00:08) [ 1/13/2017 12:55:00 PM ] Freeze code: 38257493 [ 1/13/2017 12:55:00 PM ] NET lock: 19091396 [ 1/13/2017 12:55:00 PM ] SUB lock: 00000000 [ 1/13/2017 12:55:00 PM ] SP lock: 00000000 [ 1/13/2017 12:55:00 PM ] CP lock: 00000000 [ 1/13/2017 12:55:00 PM ] SIM lock: 00000000 [ 1/13/2017 12:55:00 PM ] For check lock status: *#7465625# |
04-15-2017, 08:45 | #2 (permalink) |
Freak Poster Join Date: Jul 2014 Location: bangladesh
Member: 2227733 Status: Offline Thanks Meter: 69 | Without Root UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Read Codes Selected model: SM-J710FN Software version: 27.8 Searching Samsung modem... detected COM43 Reading phone info... Ok Model: SM-J710FN AP version: J710FXXU2AQA8 CSC version: J710FITV2AQB1 CP version: J710FXXU2AQB1 Product code: SM-J710FZDNITV Phone SN: RF8HC1172ZH Unique number: CAJ03B8EF4DD4B3 Reading IMEI... Ok IMEI: 355233082156637 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.8 |
