07-10-2017, 18:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-J710MN Unlock done QA3 build Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J710MN Software version: 28.5 Searching Samsung modem... detected COM69 Reading phone info... OK Model: SM-J710MN AP version: J710MNUBU2AQA3 CSC version: J710MNUUB2AQA3 CP version: J710MNUBU2AQA3 Product code: SM-J710MZKUTTT Phone SN: RF8J411PDKA Unique number: CAJ03F8DA4DF134 Reading IMEI... OK IMEI: 357933xxxxxxxxxx(SIGN: OK) IMEI 2: 3579xxxxxxxxxxxx (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON315 HWID: D4 06 00 00 00 00 00 00 00 00 00 00 69 36 43 57 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:12) Freeze code: 59507536 NET lock: 50868425 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 |
