08-29-2017, 17:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | SM-J710MN unlock eror Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J710MN Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-J710MN Android version: 6.0.1 Product code: SM-J710MZKUTTT Phone version: J710MNUBU3AQD2 PDA version: J710MNUBU3AQD2 CSC version: J710MNUUB3AQD2 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: MP 0.400 Phone SN: RF8J62BC7AD Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-04-01 RF cal date: 20170622 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 13.3) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.6 |
08-29-2017, 22:57 | #4 (permalink) | |
Member: 137980 Status: Offline Thanks Meter: 168 | Quote: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/009> Odin engine v(ID:3.1203).. <ID:0/009> File analysis.. <ID:0/009> SetupConnection.. <ID:0/009> Initialzation.. <ID:0/009> Get PIT for mapping.. <ID:0/009> Firmware update start.. <ID:0/009> SingleDownload. <ID:0/009> sboot.bin <ID:0/009> cm.bin <ID:0/009> FAIL! <ID:0/009> <ID:0/009> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) try to flash but error | |
