Old 08-04-2018, 23:28   #106 (permalink)
Member: 2744195
Thanks Meter: 3
Sm-j727p
You don't need to downgrade the just write nv files and you all set!!
Old 08-05-2018, 05:29   #107 (permalink)
Member: 2802156
Thanks Meter: 164
Originally Posted by yurais View Post
SO, any way to unlock by writing NV file?
correct, unless phone is elegible for unlock direct from sprint - uicc unlock option which is rare
Old 08-05-2018, 07:55   #108 (permalink)
Member: 2494408
Thanks Meter: 51
Write nvdata By DFS tool , write msl 000000
Sent from my iPhone using Tapatalk
Old 08-18-2018, 14:04   #109 (permalink)
Member: 914220
Thanks Meter: 181
j727p
phone is rooted but cant unlock
7.0 any idea
Operation: Unlock
Selected model: SM-J727P
Software version: 33.5
Waiting ADB device... OK
Reading phone info...
Model: SM-J727P
Android version: 7.0
PDA version: J727PVPU3ARC2
CSC version: J727PSPT3ARC2
Phone version: J727PVPU3ARC2
Product code: Not Active
CSC country code: USA
CSC sales code: BST
Phone SN: 00000000000
IMEI: 353559
HW version: J727P.02
RF cal date: 2017.08.19
Chip name: MSM8953
Modem board: MSM8953
Security patch: 2018-03-01
Boot Warranty bit: 1
Writing AT RIL... OK
Initialization AT RIL... root required
Checking Super user right... true
Initialization AT RIL... OK
Unlocking... error
Done with Samsung Tool PRO v.33.5
Old 09-03-2018, 03:21   #110 (permalink)
Member: 2262723
Originally Posted by rmelo2010 View Post
Pues pude desbloquear el mio sin Necesidad del MSL, Sin Root, Sin comandos. Tengo la Z3x y solo la use para flashear los archivos.
Voy a Ver lo mejor que puedo resumir lo que hice.
1.- Flashe el archivo combination .......U3ARA1 (Lo descargue de la Z3X)
2.- Una vez que subio. Le dimos donde dice IMEI. En este teclado escribi el comando *#0808#
se abre el menú activan dm-modem-adb y se activa el puerto. Buscamos el puerto. (supongo todos saben como buscar el puerto). Abrimos el programa NV Items. a) Seleccionamos puerto. b)Le dimos a conectar (Connect) c) despues le dimos a Read (Leer informacion del telefono), d) Por ultimo le dimos a escribir (Write). Seleccionamos el archivo J727p nv.
Una vez que termino de escribir le dimos donde dice Mode- Reset.
El telefono se reinicio y subio con señal. Zaaaaaaaaz
Por ultimo pase el software oficial que tenia anteriormente el de 4 archivos y el telefono siguio con señal.
Puse los apn y tiene señal y data.
Gracias esto funciono!
Old 09-03-2018, 10:54   #111 (permalink)
Member: 2360414
because they do not update to binary 3 and they pass the combination and you already know? ... they pass the files with cdma workshop, etc. it is also permanent
Old 10-01-2018, 20:17   #112 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 135
samsung sm-j727P U4 UNLOCK ERROR
UNLOCK INSTRUCTIONS:
Domestic Unlock:
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock Domestic' button.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Software version: 33.2
Model: SM-J727P
PDA version: J727PVPU4ARG2
CSC version: J727PSPT4ARG2
Phone version: J727PVPU4ARG2
Product code: SM-G950UZBABST
CSC sales code: BST
IMEI: 355743092485552
HW version: JoelHeredi
RF cal date: 2017.03.16
Chip name: MSM8953
Security patch: 2018-07-01
Unlocking... error
Done with Samsung Tool PRO v.33.2
Old 12-06-2018, 20:16   #113 (permalink)
Member: 2597589
Combination file?
what is the combination file right, for the Firmware Smsung SM-J727P_J727PVPU4ARG2
i need a combination file, because the celphone is restarting for 5 seconds each...
Please help me
Old 12-27-2018, 16:16   #114 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 460
Model: SM-J727P
Android version: 8.1.0
PDA version: J727PVPU4BRH5
CSC version: J727PSPT4BRH5
Phone version: J727PVPU4BRH5
CSC sales code: XAS
IMEI: 353559086282900
RF cal date: 2018.01.08
Chip name: MSM8953
Security patch: 2018-08-01
SIM State: ABSENT
Searching Samsung diag port... detected COM337
Writing data to phone... error (2)
Could not read lock item. New security type detected.
Done with Samsung Tool PRO v.34.6
Old 12-27-2018, 17:44   #115 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,927
I don’t think bin 4 will work this solution
Old 01-15-2019, 13:37   #116 (permalink)
Member: 322417
Thanks Meter: 901
Originally Posted by chendorj View Post
only gc pro box has worked for me in this device z3x could unlock it
Can you provide any Video proof ?
Page generated in 0.35989 seconds with 7 queries
