10-04-2018, 14:38 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2522678 Status: Offline Thanks Meter: 3 | SM-j730f Security patch: 2018-09-01 [Answered] REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-J730F Software version: 33.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J730F Android version: 7.0 PDA version: J730FXWS3ARI7 CSC version: J730FOJV3ARI1 Phone version: J730FXXU3ARI2 Product code: SM-J730FZDDMID CSC country code: Iraq CSC sales code: MID Phone SN: R28J635ZG3W IMEI: xxxxxxxxxx HW version: MP 0.400 RF cal date: 20170626 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-09-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 13.3) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible |
