04-29-2016, 10:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | Samsung Galaxy S6 G920F DRK SUCCESS Z3X Power on phone in download mode. Connect phone to PC with USB cable, install drivers if needed. Press 'Repair DRK' button. Checking Recovery file... OK Searching USB Flash Interface... detected COM4 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G920FXXU3DPBN Platform: exynos7420 Boot serial: 03157df399444632 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... OK Checking DRK status... Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.2 |
05-29-2016, 16:10 | #2 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1825357 Status: Offline Sonork: hawlk5 Thanks Meter: 0 | Does the phone need to be rooted? I have a samsung galaxy s6 edge plus G9287 with drk verification error. But when I use the box Z3x version 25.5 I get Waiting for adb timeout Phone not found. Please help. Sent from my LG-D858HK using Tapatalk |
05-31-2016, 13:05 | #4 (permalink) | |
Member: 1825357 Status: Offline Sonork: hawlk5 Thanks Meter: 0 | Quote:
Sent from my LG-D858HK using Tapatalk | |
09-04-2016, 20:20 | #7 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 42
Member: 63646 Status: Offline Sonork: 1670920:45069 Thanks Meter: 23 | I tried to do DRK repair S6 G920F for me this is not working , someone can help me ? this is log : 4-9-2016 20:51:00 ] Checking local file... OK [ 4-9-2016 20:51:00 ] Searching server... OK [ 4-9-2016 20:51:00 ] Compare local and server file... OK (up to date) [ 4-9-2016 20:51:00 ] Searching USB Flash Interface... detected COM28 [ 4-9-2016 20:51:00 ] Setup connection... OK [ 4-9-2016 20:51:00 ] Reading data from phone... OK [ 4-9-2016 20:51:00 ] Sending data to phone... OK [ 4-9-2016 20:51:00 ] Sending data to phone... OK [ 4-9-2016 20:52:00 ] Waiting ADB device... OK [ 4-9-2016 20:52:00 ] Reading phone info... [ 4-9-2016 20:52:00 ] Recovery build version: 6.0.1 [ 4-9-2016 20:52:00 ] Boot version: G920FXXU4DPG8 [ 4-9-2016 20:52:00 ] Platform: exynos7420 [ 4-9-2016 20:52:00 ] Boot serial: 031603b5cb431101 [ 4-9-2016 20:52:00 ] Product board: zerolte [ 4-9-2016 20:52:00 ] Initializating zTool... OK [ 4-9-2016 20:52:00 ] Running zTool, please wait... [ 4-9-2016 20:52:00 ] Start... OK [ 4-9-2016 20:52:00 ] Init... OK [ 4-9-2016 20:52:00 ] Generate and check client proof... OK [ 4-9-2016 20:52:00 ] Verify proof by client... OK [ 4-9-2016 20:52:00 ] Checking DRK status... OK [ 4-9-2016 20:52:00 ] Repairing DMVT key... drk repair stops at this point |
11-30-2016, 11:17 | #8 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Checking Recovery file... OK Searching USB Flash Interface... detected COM4 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G920FXXU3DPBN Platform: exynos7420 Boot serial: 03157df399444632 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... OK Checking DRK status... Repairing DMVT key... OK Rebooting phone... OK Repair DRK done z3x fix dmvt keys but when phone boot normal then *#06# not working and touch reverse |
05-04-2017, 13:35 | #9 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: wazirabad gujranwala pakistan Age: 30
Member: 2158722 Status: Offline Sonork: 1668812 Thanks Meter: 39 | bro after riper hang on logo of samsung Quote:
08-16-2017, 13:05 | #10 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1546501 Status: Offline Thanks Meter: 15 | how to solw this problem REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G920F Software version: 29.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM21 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G920FXXU5EQAC Platform: exynos7420 Boot serial: 05157df53487bd3a Product board: zeroflte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.29.0 |
10-12-2018, 16:57 | #11 (permalink) | |
Major Poster Join Date: Aug 2016
Member: 2614003 Status: Offline Thanks Meter: 1 | Quote:
Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G920F Software version: 33.7 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM202 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G920FXXU5EQG5 Platform: exynos7420 Boot serial: 02157df26a8b1613 Product board: zeroflte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.33.7 | |
