Old 10-11-2018, 22:50   #1 (permalink)
Member: 1861478
Thanks Meter: 6
SM-J730gm modem downgrade [Answered]
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
Operation: Repair
Selected model: SM-J730GM
Software version: 33.8
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... OK
Reading phone info...
Model: SM-J730GM
Android version: 8.1.0
PDA version: J730GMDXU5BRI3
CSC version: J730GMOLD5BRI3
Phone version:
Product code:
CSC country code: THAILAND
CSC sales code: THL
Phone SN:
IMEI:
HW version:
RF cal date:
Chip name: EXYNOS7870
Modem board:
Security patch: 2018-08-01
Boot Warranty bit: 0
Checking Super user right... true
Reading NV data... OK
Checking NV data... error
Security damaged (decompress error)
Done with Samsung Tool PRO v.33.8
PLZ HELLP DOWNGRADE MODEM SECURITY PATCH 2018-08-01
Old 10-11-2018, 22:56   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 988
Try repair unkown baseband then repair nvdata
Old 10-12-2018, 00:06   #3 (permalink)
Member: 1861478
Thanks Meter: 6
FIXED BASBAND ok. no networkfixed. only emergency calls only
error modem downgrade Can not be repaired
Old 10-12-2018, 05:14   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 988
Flash modem from combination same binary rev and retry repair
The Following User Says Thank You to souma_k For This Useful Post:
Old 10-12-2018, 10:38   #5 (permalink)
Member: 1861478
Thanks Meter: 6
I got a flash combination after write combination imei ok basband ok emergncy calls onlly icon 🚫
Old 10-12-2018, 10:46   #6 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 988
Check *#0011# imei certi and mipi device success or failed
Old 10-12-2018, 10:52   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 609
just flash update firmware your baseband and imei will be ok no need write ceart,efs etc
Old 10-12-2018, 12:06   #8 (permalink)
Member: 1861478
Thanks Meter: 6
**0011# screenshots
patch certifacte ok
Operation: Patch Certificate
Software version: 33.7
Model: SM-J730GM
Phone version: J730GMDXU5BRI3
Product code: SM-J730GZKUTHL
CSC sales code: THL
Phone SN: RF8JB2QANLW
IMEI: 860931022704295
HW version: MP 0.400
RF cal date: 20171219
Modem board: SHANNON315
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Initialization data... OK
Writing zTool... OK
Initialization zTool... OK
Rebooting phone... OK
Patching CERT check... done
Done with Samsung Tool PRO v.33.7
Old 10-12-2018, 15:20   #9 (permalink)
Member: 1861478
Thanks Meter: 6
Hellp z3x team sulotion NG imei status repaier
Old 10-12-2018, 17:19   #10 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 988
8.1 no support for imei repair
Old 10-13-2018, 00:29   #11 (permalink)
Member: 1861478
Thanks Meter: 6
Is Dongle chamira support ?
Page generated in 0.13452 seconds with 7 queries
