07-21-2015, 17:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: bahrain.
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | sm-n7505 imei null i have sm-n7505 imei null. can i fix this z3x pro? write efs, try to write cert, but faile here is log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N7505 Software version: 21.8 Checking certificate file... OK KEY ID: 0028 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N7505 Android version: 4.4.2 Product code: Phone version: PDA version: N7505XXUCNH1 CSC version: N7505OJVCNH2 CSC country code: KSA CSC sales code: KSA HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... SSNV not found Done with Samsung Tool PRO v.21.8 |
