05-05-2015, 19:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | SM-N900 read CERT Fail i'm getting error while reading cert from a SM-N900 phone: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Read CERT Selected model: SM-N900 Software version: 21.0 Waiting ADB device... OK Reading phone info... Model: SM-N900 Android version: 5.0 Product code: SM-N9000ZWEXSG Phone version: N900XXUEBNL6 PDA version: N900XXUEBOA6 CSC version: N900SEREBOA6 CSC country code: Russia CSC sales code: SER HW version: MP 0.600 Phone S/N: R51FA16F0WR Modem board: XMM6360 RF cal date: 2014.10.21 IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Security damaged or incorrect key Done with Samsung Tool PRO v.21.0 |
05-06-2015, 20:07 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
did you try full reset phone, may-be there installed lot of different application.? | |
05-06-2015, 21:07 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
Security damaged or incorrect key This is your answer | |
05-06-2015, 22:10 | #4 (permalink) | |
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
NOPE,, it was android 5.0 problem.. i downgraded back to 4.4.2 and reads good. and i tested the cert also. all is ok.. it seems the problem was with 5.0 .. tried to use Octopus box to read the cert. they can read it, but cert not usable. downgrade to 4.4.2 and all works good. | |
