02-17-2018, 15:30 | #91 (permalink) | |
Insane Poster Join Date: Feb 2014
Member: 2125344 Status: Offline Thanks Meter: 29 | Great Quote:
Your post helped me a lot.. Regards | |
07-09-2019, 11:16 | #93 (permalink) |
Freak Poster Join Date: Aug 2014 Location: khulna bangladash
Member: 2243325 Status: Offline Sonork: 01715634715 Thanks Meter: 28 | ALL FLASH FILE TASTED Index of ./ |
09-08-2020, 11:47 | #94 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910C Software version: 29.2 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: N910CXXU1DPI1 PDA version: N910CXXS2DRL1 CSC version: N910COJV2DRL1 CSC country code: South Africa CSC sales code: XFM HW version: Phone SN: 00000000000 Modem board: DB7450R Security patch: 2017-08-01 RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading NV data... OK Analyzing NV data... error Security damaged Done with Samsung Tool PRO v.29.2 |
