02-15-2016, 13:32 | #1 (permalink) |
Insane Poster Join Date: Feb 2012 Location: karachi,Pakistan Age: 32
Member: 1727457 Status: Offline Sonork: 100.1603980 Thanks Meter: 26 | SM-N9208 FRP error.. Selected model: SM-N9208 Software version: 24.2 Searching Samsung USB Flash Interface... detected COM14 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.24.2 |
03-09-2016, 13:16 | #2 (permalink) |
Member: 1727457 Status: Offline Sonork: 100.1603980 Thanks Meter: 26 | Operation: Reset FRP/React/EE Selected model: SM-N9208 Software version: 24.6 Searching Samsung USB Flash Interface... detected COM27 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.6 |
05-30-2016, 12:38 | #3 (permalink) |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-N9208 Software version: 25.5 Searching Samsung USB Flash Interface... detected COM123 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.25.5 |
