02-29-2016, 18:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | SM-N920S Erasing Reactivation lock... error Selected model: SM-N920S Software version: 24.4 Searching Samsung USB Flash Interface... detected COM5 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.24.4 I wiped phone, flashed phone but still same result. any help please? thanks |
03-10-2016, 16:00 | #9 (permalink) |
Freak Poster Join Date: Dec 2007 Location: indonesia
Member: 658821 Status: Offline Thanks Meter: 12 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-N920S Software version: 24.6 Searching Samsung USB Flash Interface... detected COM9 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.6 succes but telephone please call me |
07-12-2016, 18:04 | #13 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Romania
Member: 323255 Status: Offline Thanks Meter: 67 | Thank you. After trying almoust everything i managed to reset FRP using this version of firmware. Before that i've tryed 4 flash files but no succes. This version works! N920SKSU2AOI8 Thanks |
