09-14-2016, 00:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | SM-N920T fail remove FRP Operation: Reset FRP/React/EE Selected model: SM-N920T Software version: 26.6 Searching Samsung USB Flash Interface... detected COM13 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.26.6 Need Help to solve this. |
09-14-2016, 02:40 | #5 (permalink) |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | After flashing the eng-boot which gives shell root, just erase the security partition by entering this in Command Prompt, phone has to be on the boot up screen get the file from here and make sure you thank the guy http://forum.gsmhosting.com/vbb/f922...-free-2123028/ adb shell dd if=/dev/zero of=/dev/block/sda11 adb reboot I just did it and it work!! |
The Following User Says Thank You to JT man For This Useful Post: |
09-14-2016, 12:55 | #10 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | I have tryed to flash that file but Odin dont flash, in Odin i have message "NAND write start" but no progress , not flash and in Phone no error message. |
09-14-2016, 16:01 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Look at the error message in the pic. You have a rom on the phone that has RP of 3 and you are trying to flash a sboot from a rom that has a RP of 2. If you dont have eng root. just flash the eng sboot from the combo file that has the RP of 3 then put into download and wipe frp via z3x and then flash stock sboot back to phone. Catch up people. this has been an issue since the december 2015 security update...coming up on a year now. You would think a year is long enough to catch on. I myself have posted about a dozen posts on this issue. Whether or not its the exact same model doesnt matter..it is the same dang concept. |
The Following 2 Users Say Thank You to markhaines1985 For This Useful Post: |
09-15-2016, 01:48 | #12 (permalink) | |
Member: 85718 Status: Offline Thanks Meter: 449 | Quote:
In my Phone i have the information RP SWREV : B:2 K:0 S:0 Is safe downgrade , and if downgrade the Unlock Is more easy ? | |
