06-02-2016, 01:28 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2380546 Status: Offline Thanks Meter: 0 | Sm-n920t reset efs error REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Reset EFS Selected model: SM-N920T Software version: 25.5 Waiting ADB device... OK Reading phone info... Model: SM-N920T Android version: 6.0.1 Product code: SM-N920TZWATMB Phone version: N920TUVU2DPD1 PDA version: N920TUVU2DPD1 CSC version: N920TTMB2DPD1 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8GA0G0WHT Modem board: SHANNON333 RF cal date: 20151005 IMEI: Checking Super user right... true Backuping EFS... error (1) Reseting EFS... error Done with Samsung Tool PRO v.25.5 |
06-02-2016, 06:24 | #3 (permalink) |
Freak Poster Join Date: May 2006 Location: U.S.A.
Member: 285890 Status: Offline Thanks Meter: 72 | Not possible on z3x, the software looking for EFS partition, which is on different location, in fact there are 2 EFS partitions. as far as i know only GCPRO to wipe both EFS. |
