07-18-2016, 23:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Morocco
Member: 136492 Status: Offline Thanks Meter: 289 | SM-N920v frp remove [Done] Searching Samsung USB Flash Interface... detected COM4 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.0 |
The Following 19 Users Say Thank You to CHEZRACHID For This Useful Post: |
09-23-2016, 04:11 | #2 (permalink) |
Crazy Poster Join Date: Sep 2016
Member: 2622037 Status: Offline Thanks Meter: 9 | dear friend, im getting error ...any idea ? Operation: Reset FRP/React/EE Selected model: SM-G920V Selected port: COM7 RIM Virtual Serial Port v2 Software version: 26.7 Searching Samsung USB Flash Interface... detected COM3 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.26.7 |
09-23-2016, 04:24 | #3 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Quote:
The Following User Says Thank You to ct3im For This Useful Post: |
09-23-2016, 06:25 | #6 (permalink) |
Member: 2622037 Status: Offline Thanks Meter: 9 | anyway, finally i was able to remove the frp after downgrading to OJ3 and using z3tool Thanks Everyone...Salut Operation: Reset FRP/React/EE Selected model: SM-N920P Software version: 26.7 Searching Samsung USB Flash Interface... detected COM3 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.7 |
The Following 3 Users Say Thank You to altnoc For This Useful Post: |
11-09-2016, 03:46 | #7 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2626198 Status: Offline Thanks Meter: 1 | Hi ,............. Please help me to remove Samsung SM-G920V Ver. 6.0.1 FRP ( Marshmallow ) , I was trying to remove it with Samsung Tool Pro v.27 unable to remove. kindly share steps to remove I will be very thankful to you. In above you have mentioned downgrade to OJ3 where I can find this file to download ? Thanks & Regards Noman |
11-09-2016, 03:59 | #8 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
04-18-2017, 17:31 | #10 (permalink) | |
Junior Member Join Date: Feb 2010
Member: 1226638 Status: Offline Thanks Meter: 5 | N920v FRP Removal Quote:
I used Samsung Tool Pro v28.1 to remove FRP lock from N920v 6.0.1 BBand v QB1, I selected G920v and selected Reset FRP /React/EE under unlock, z3x gave me frp removal is successful, but on the screen of the N920v still showing me its still working, so I turned the phone off by clicking power button and the volume down button, then the phone powered on with a menu that has 5 selections, i choosed number 5 to enable ADB settings or something like this, then the phone rebooted and went to the main menu with a working phone and FRP was removed. hope this work for every one. Thanks | |
The Following 3 Users Say Thank You to cricket_wireles For This Useful Post: |
09-10-2017, 07:34 | #12 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Even easier, just flash the "sboot.bin" from Samsung_N920V_VRU3BPL4_v6.0.1_SB_FRP.TAR https://www.androidfilehost.com/?fid=961840155545594471 and use model N920P to Reset/React/EE FRP on N920V. Then just flash back the original "sboot.bin" you're currently on. Note that v6.0.1 "sboot.bin" can be even flashed over v7.x.x as long as the fourth digit in the firmware is a "3". |
The Following 12 Users Say Thank You to BillA For This Useful Post: |
12-18-2017, 14:28 | #14 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Spokane, WA USA Age: 52
Member: 2121706 Status: Offline Thanks Meter: 3 | Sm-n920v & I am needing to do this also but I cannot find a valid download link for Samsung Tool PRO v.26.0 Can someone please link me to a working Samsung Tool PRO v.26.0? I have been searching the webz for hourz and it is all click-bait revolving neverending ads and malware |
The Following User Says Thank You to donniegalaxy2 For This Useful Post: |
03-27-2018, 12:49 | #15 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1432040 Status: Offline Thanks Meter: 3 | good work Quote:
