Old 07-18-2016, 23:53   #1 (permalink)
CHEZRACHID's Avatar
Member: 136492
Thanks Meter: 289
SM-N920v frp remove [Done]
just select G920v AND dont forget to thanks the great Z3X Box Team.
Searching Samsung USB Flash Interface... detected COM4
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... OK
Erasing Reactivation lock... OK
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Done with Samsung Tool PRO v.26.0
The Following 19 Users Say Thank You to CHEZRACHID For This Useful Post:
Old 09-23-2016, 04:11   #2 (permalink)
Crazy Poster
Member: 2622037
Thanks Meter: 9
dear friend,
im getting error ...any idea ?
Operation: Reset FRP/React/EE
Selected model: SM-G920V
Selected port: COM7 RIM Virtual Serial Port v2
Software version: 26.7
Searching Samsung USB Flash Interface... detected COM3
Erasing FRP... OK
Erasing Reactivation lock... error
Done with Samsung Tool PRO v.26.7
Old 09-23-2016, 04:24   #3 (permalink)
Member: 85718
Thanks Meter: 449
Originally Posted by altnoc View Post
dear friend,
Erasing FRP... OK
If you have android 6 , try downgrade to 5.
The Following User Says Thank You to ct3im For This Useful Post:
Old 09-23-2016, 04:36   #4 (permalink)
Member: 1025079
Thanks Meter: 311
if phone has last version use eng file to enable adb
Old 09-23-2016, 05:08   #5 (permalink)
Crazy Poster
Member: 2622037
Thanks Meter: 9
Friend, what do you mean by eng file ?
Firmware version is BPF41
btw, how to enable adb ? i can only go to download mode or recovery mode
please advice
Old 09-23-2016, 06:25   #6 (permalink)
Crazy Poster
Member: 2622037
Thanks Meter: 9
anyway, finally i was able to remove the frp after downgrading to OJ3 and using z3tool
Thanks Everyone...Salut
Selected model: SM-N920P
Erasing FRP... OK
Reset done
The Following 3 Users Say Thank You to altnoc For This Useful Post:
Old 11-09-2016, 03:46   #7 (permalink)
Member: 2626198
Hi ,.............
Please help me to remove Samsung SM-G920V Ver. 6.0.1 FRP ( Marshmallow ) , I was trying to remove it with Samsung Tool Pro v.27 unable to remove. kindly share steps to remove I will be very thankful to you.
In above you have mentioned downgrade to OJ3 where I can find this file to download ?
Thanks & Regards
Noman
Old 11-09-2016, 03:59   #8 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Originally Posted by syedali1983 View Post
Hi ,.............
Thanks & Regards
Noman
maitain mod enble usb than easy remove
Old 11-09-2016, 09:26   #9 (permalink)
Member: 2604925
Thanks Meter: 7
no need combination file sir...?
Old 04-18-2017, 17:31   #10 (permalink)
Member: 1226638
Thanks Meter: 5
N920v FRP Removal
Erasing FRP... OK
Reset done
I used Samsung Tool Pro v28.1 to remove FRP lock from N920v 6.0.1 BBand v QB1, I selected G920v and selected Reset FRP /React/EE under unlock, z3x gave me frp removal is successful, but on the screen of the N920v still showing me its still working, so I turned the phone off by clicking power button and the volume down button, then the phone powered on with a menu that has 5 selections, i choosed number 5 to enable ADB settings or something like this, then the phone rebooted and went to the main menu with a working phone and FRP was removed. hope this work for every one. Thanks
The Following 3 Users Say Thank You to cricket_wireles For This Useful Post:
Old 06-21-2017, 17:07   #11 (permalink)
Member: 2558440
Thanks Meter: 4
It worked like a charm!!.��
Old 09-10-2017, 07:34   #12 (permalink)
Member: 92260
Thanks Meter: 843
Even easier, just flash the "sboot.bin" from Samsung_N920V_VRU3BPL4_v6.0.1_SB_FRP.TAR
https://www.androidfilehost.com/?fid=961840155545594471
and use model N920P to Reset/React/EE FRP on N920V.
Then just flash back the original "sboot.bin" you're currently on.
Note that v6.0.1 "sboot.bin" can be even flashed over v7.x.x as long as the fourth digit in the firmware is a "3".
The Following 12 Users Say Thank You to BillA For This Useful Post:
Old 11-30-2017, 02:05   #13 (permalink)
Member: 2136869
Thanks Meter: 10
billa dude you are such much ka billa love u best solution dear
The Following User Says Thank You to Cute Khan For This Useful Post:
Old 12-18-2017, 14:28   #14 (permalink)
Member: 2121706
Thanks Meter: 3
Sm-n920v &
just select G920v ...
... with Samsung Tool PRO v.26.0
I am needing to do this also but I cannot find a valid download link for Samsung Tool PRO v.26.0
Can someone please link me to a working Samsung Tool PRO v.26.0?
I have been searching the webz for hourz and it is all click-bait revolving neverending ads and malware
The Following User Says Thank You to donniegalaxy2 For This Useful Post:
Old 03-27-2018, 12:49   #15 (permalink)
Member: 1432040
Thanks Meter: 3
Thumbs up good work
Erasing FRP... OK
Reset done
good work thanks frb off
Page generated in 0.26567 seconds with 8 queries
