08-05-2018, 14:52 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2180898 Status: Offline Thanks Meter: 9 | SM-N950F Unlock done. 8.0 NO COMBO NEEDED! UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Operation: Read Codes via Server Selected model: SM-N950F Software version: 33.5 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM215 Reading phone info... Model: SM-N950F AP version: N950FXXU3CRF4 CSC version: N950FOXM3CRF7 CP version: N950FXXU3CRF2 Product code: MAT Phone SN: IMEI: Unique number: Searching Samsung diag port... detected COM216 Reading phone info... OK CP version: N950FXXU3CRF2 CP build: Jun 8 2018 15:06:59 Reading data from phone... error (1) Searching server... OK Checking available files... OK Available CP file for downgrade, try download and flash? Continue? Yes Downloading file... OK Checking local file... OK Switching to flash mode... OK Searching USB Flash interface... COM174 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Searching Samsung modem... detected COM215 Reading phone info... Model: SM-N950F AP version: N950FXXU3CRF4 CSC version: N950FOXM3CRF7 CP version: N950FXXU3ARA1 Product code: MAT Phone SN: IMEI: Unique number: Searching Samsung diag port... detected COM216 Reading phone info... OK CP version: N950FXXU3ARA1 CP build: Jan 9 2018 14:30:26 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 73830638 NET lock: 79057384 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 *I REMOVED IMEI AND SERIAL NUMBERS FOR PRIVACY |
08-07-2018, 22:47 | #2 (permalink) | |
Freak Poster Join Date: Jun 2016
Member: 2592628 Status: Offline Thanks Meter: 212 | why Quote:
Why are we garbage posting server operations. They're nothing special. This model can be unlocked without credits fairly easily....nobody impressed by server credit method. OOO AAHH so magical you click one button and pay money | |
10-01-2018, 22:39 | #3 (permalink) | |
Freak Poster Join Date: Jun 2013 Location: Tampa FL
Member: 1968939 Status: Offline Thanks Meter: 20 | Quote:
what tool then can unlock it without credits??? | |
04-30-2019, 20:33 | #4 (permalink) | |
Member: 2180898 Status: Offline Thanks Meter: 9 | Lol!!! Quote:
When you do volume like us, 30-40 phones per day, you will appreciate the solution. Funny how you came to hate on me, when I dont know you from a hole in the wall FOH!!! Go F*ck yourself | |
