SM-N950U1 TMB unlock read codes by server problem [Answered] I read codes by server without problem phone ask for code but when enter shows accepted and it asks again for code you can enter any number would say correct but remains lock, havent flash it yet waiting for instructions
Thanks in advance i attach log:
phone is 0x0 with original system and binary Quote:
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will appear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Unlocking TMB using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Unlocking SPR using sever:
1. Insert not SPR card to the phone and power it on.
5. Press 'Unlock...' button, select 'Unlock SPR via Server',
Reading codes using sever:
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
Operation: Read Codes via Server
Selected model: SM-N950U1
Selected port: COM8 USB Serial Port
Software version: 34.11
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-N950U1
Android version: 8.0.0
PDA version: N950U1UEU5CRK1
CSC version: N950U1OYM5CRK1
Phone version: N950U1UEU5CRK1
Product code: SM-N950UZVATMB
CSC country code: USA
CSC sales code: TMB
Phone SN: R28J82LMWCF
IMEI: 35182
HW version: REV1.0
RF cal date: 2017.08.18
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-11-01
Boot Warranty bit: 0
SIM State: ABSENT
This phone may be locked to TMB and may not unlock via codes Continue? Yes
Rebooting phone... OK
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait... OK
Reading data from phone... OK
Searching Samsung diag port... detected COM304
Reading phone info... OK
Searching Ramdump interface... COM263 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 17262038
NET lock: 42728602
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.34.11
