Old 02-22-2019, 02:27   #1 (permalink)
Member: 2092797
Thanks Meter: 4
SM-N950U1 TMB unlock read codes by server problem [Answered]
I read codes by server without problem phone ask for code but when enter shows accepted and it asks again for code you can enter any number would say correct but remains lock, havent flash it yet waiting for instructions
Thanks in advance i attach log:
phone is 0x0 with original system and binary
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will appear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Unlocking TMB using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Unlocking SPR using sever:
1. Insert not SPR card to the phone and power it on.
5. Press 'Unlock...' button, select 'Unlock SPR via Server',
Reading codes using sever:
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
Operation: Read Codes via Server
Selected model: SM-N950U1
Selected port: COM8 USB Serial Port
Software version: 34.11
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-N950U1
Android version: 8.0.0
PDA version: N950U1UEU5CRK1
CSC version: N950U1OYM5CRK1
Phone version: N950U1UEU5CRK1
Product code: SM-N950UZVATMB
CSC country code: USA
CSC sales code: TMB
Phone SN: R28J82LMWCF
IMEI: 35182
HW version: REV1.0
RF cal date: 2017.08.18
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-11-01
Boot Warranty bit: 0
SIM State: ABSENT
This phone may be locked to TMB and may not unlock via codes Continue? Yes
Rebooting phone... OK
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait... OK
Reading data from phone... OK
Searching Samsung diag port... detected COM304
Reading phone info... OK
Searching Ramdump interface... COM263 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 17262038
NET lock: 42728602
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.34.11
Old 02-23-2019, 02:26   #2 (permalink)
Member: 2092797
Thanks Meter: 4
Flash and hard reset with N950U1UEU5CRL2 is still the same accept any code accepted but not unlock, ahhh and devices unlock app is not present in any version and ask for codes since the beginning i have videos and photos if needed.
File analysis... OK
Total file size: 0x190553026 (6405 Mb)
Searching USB Flash interface... COM263 detected
Setup connection... OK
Set PIT file... OK
Reading PIT from phone... OK
Sending abl.elf.lz4... OK
Sending bksecapp.mbn.lz4... OK
Sending xbl.elf.lz4... OK
Sending tz.mbn.lz4... OK
Sending hyp.mbn.lz4... OK
Sending devcfg.mbn.lz4... OK
Sending pmic.elf.lz4... OK
Sending rpm.mbn.lz4... OK
Sending cmnlib.mbn.lz4... OK
Sending cmnlib64.mbn.lz4... OK
Sending keymaster.mbn.lz4... OK
Sending apdp.mbn.lz4... OK
Sending msadp.mbn.lz4... OK
Sending sec.dat.lz4... OK
Sending NON-HLOS.bin.lz4... OK
Sending storsec.mbn.lz4... OK
Sending boot.img.lz4... OK
Sending recovery.img.lz4... OK
Sending system.img.ext4.lz4... OK
Sending persist.img.ext4.lz4... OK
Sending dqmdbg.img.ext4.lz4... OK
Sending userdata.img.ext4.lz4... OK
Sending modem.bin.lz4... OK
Sending adspso.bin.lz4... OK
Sending cache.img.ext4.lz4... OK
Flashing done (time - 00:08:33)
Old 02-25-2019, 20:26   #3 (permalink)
Member: 2092797
Thanks Meter: 4
i try to install devices unlock app to check but when run it says this application is not compatible with this device...
knox is 0x0
3 post and no support? i am missing something?
Old 02-25-2019, 21:16   #4 (permalink)
Member: 2092797
Thanks Meter: 4
thanks i will check and let you know, i agreethe same as try to unlock it as app device...
Originally Posted by gsm_service4u View Post
this is odd
if it's actual TMB then should give codes like 12345678
try flashing combination and doing g930p unlock it will work if phone actually sprint, other than that flash n950u and insert tmobile sim for unlock app to appear
Old 02-25-2019, 22:05   #5 (permalink)
Member: 1820439
Thanks Meter: 146
flash tmobile version of n950u with modded odin and then unlock via z3x tmobile unlock via server then flash n950u1 with modded odin again and done
Old 02-28-2019, 00:31   #6 (permalink)
Member: 2092797
Thanks Meter: 4
I try g930p unlock shows unlock but remains locked, i attach log, then i check imei on tmobile page and it shows as reported, so that confirms to be tmo i make flash but with n950u with user and got the app and do server unlock. seems to be working
Model: SM-N950U
Android version: 7.1.1
PDA version: FA71_N950USQU5ARG2
CSC version:
Phone version: N950USQU5ARF1
CSC country code:
CSC sales code:
Phone SN: R28Jxxxxxxxxxx
IMEI: 3518xxxxxxxxxx
HW version: REV1.0
Chip name: MSM8998
Security patch: 2017-07-01
Incorrect model selected. This may damage your phone. Continue? Yes
Writing AT RIL... OK
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Old 03-03-2019, 22:40   #7 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 178,041
you can not read codes for TMB phone.
this posted many times.
only TMB unlock work for this phone.
The Following User Says Thank You to blang For This Useful Post:
Page generated in 0.30025 seconds with 7 queries
