10-26-2018, 16:53 | #61 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Version Android 7.0 Changelist 13839138 Build date Thu, 20 Sep 2018 07:21:41 +0000 Security Patch Level 2018-10-01 Product code PDA T580XXS4BRI1 Then when you choose the firmware for t580 binary 4 you choose the according to the firmware of the country or region you have installed on your tablet | |
10-30-2018, 18:01 | #62 (permalink) | |
Insane Poster Join Date: Mar 2007 Location: paris
Member: 465404 Status: Offline Thanks Meter: 11 | Quote:
https://samsung-firmware.org/fr/amp/.../T580OXA4BRI1/ | |
11-18-2018, 10:19 | #63 (permalink) |
No Life Poster Join Date: Oct 2011 Location: gsmsection
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | SM-T580 U4 FRP reset how to ? hi to all any way to bypass frp T580 U4 Itry with combination not succes how to solve any idea? thanks in advance |
11-22-2018, 05:27 | #69 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2148129 Status: Offline Thanks Meter: 42 | I can remove any FRP or React in just 30 sec. No hassle, no firmware, no boots or combos. Just plug and play. Totally remote. PM me of anyone need support. Also can repair any CPID imei like N9, S9 same day 15 to 30 min. |
11-26-2018, 09:16 | #72 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | This is a tested solution for all versions 7.0, 7.1.1, on binary 2,3,4 If your tablet is on binary 3 1.Flash binary 3 combination 2. Flash ONLY system from BINARY 2 stock firmware 3. After that it will automatically bypass the frp screen then go to settings and reset the phone. 4. Now frp is completely removed, but you have to flash full binary 3 firmware because the screen inverts sometimes. IF your tablet is binary 4 you have to do the same thing but this time you have to flash system from binary 3. Tested on SM-T580 AND SM-T585! |
The Following 2 Users Say Thank You to Feiselski For This Useful Post: |
11-29-2018, 11:50 | #73 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 42
Member: 63646 Status: Offline Sonork: 1670920:45069 Thanks Meter: 23 | This is not working for me, Samsung was on bin3 (u3) tried to flash bin3 combination this gives error during flasing: File analysis... OK Total file size: 0x3EC975B0 (1004 Mb) Searching USB Flash interface... COM11 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... error timeout Done with Samsung Tool PRO v.34.3 on display from T580 it shows : FRP is enabled. ignore PIT download FRP is enabled not allow download non-FRP Bootloader binary I tried this also with U4 version gives same error |
11-29-2018, 12:19 | #74 (permalink) |
Major Poster Join Date: Dec 2005 Location: Romania Age: 41
Member: 205302 Status: Offline Thanks Meter: 5 | SM-T580 Frp Succes T580XXU4CRJ9!! Procedure: flash COMBINATION_FA60_T580XXU4ARJ1_CL10816856_QB2011243 6_REV00_user_mid_noship.tar Octopus box frp by uart. |
The Following 2 Users Say Thank You to aditza For This Useful Post: |
