Old 03-22-2017, 09:56   #16 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 213
Originally Posted by tipitiboss View Post
After flash conbination file get recovery menu, get usb debug work, reset frp, after that reset via menu and now phone is bricked, only get the message "emmc checksun is fail", no download mode and no recovery, plug in the computer and nothing .
Force to enter download mode by press vol down+home + power for two minutes with usb cable.
Have u flash only boot or all files for combination?
Originally Posted by trockunlock
I have solution for frp without any tool
Remember you not have any sim reader in this model.
Old 03-25-2017, 11:54   #17 (permalink)
Member: 2696252
Pit Error
If i try to flash i get a error from Pit.
Maybe you can help me.
Old 03-27-2017, 15:48   #18 (permalink)
Member: 8379
Thanks Meter: 34
T580
firmware t580xxu2apl4 cannot remove FRP
Cannot download grade to any t580xxu1
cannot flash combination file t580xxu2apl1
Any solution ?
anyone have t580xxu2apl4 combination file ?
Old 04-19-2017, 17:46   #19 (permalink)
Crazy Poster
Member: 848549
Thanks Meter: 9
FOUND THIS ON XDA
I was having the same problem, but i figured it out last night. Without OTG cable, Odin, SideSync, Realtek, or a PC. I'd been messing with it for 3 days, so Im not 100% sure of what everything said and i'm definitely not going to relock it to try an duplicate it, but if you've been all over youtube then you've seen methods that require a wifi connection, (I found it easiest to use my phone's wifi hotspot) you disconnect your hotspot or unplug your router immediately when it says checking for software update, which appears after clicking accept on the privacy policy. (Again it's easier to just turn off the hotspot than to unplug your router" When done correctly it souls say "couldn't sign in" and then the next screen will either ask you to set up time and date or it asks you to add a name to the tablet (can't remember which is first) then asks to set up a screen lock passcode or pattern (set up either one), after doing all this 100 times I noticed it asked me if i wanted to set up a IMAP/POP3 account to use within the Gmail app (which I'd been skipping) but for some reason it didn't give me this option every time. You have to be connected to the internet for the next part so if you haven't already go ahead and turn your hotspot back on or router and add any email address other than a Gmail (I used my yahoo account) then follow through with the setup into it takes you back to the very first screen you see when you turned on the tablet. Now just turn the tablet screen off and back on (just the screen, do not power down the tablet) put in your lockscreen password and now In the top right corner there should be a little yellow icon which lets you switch users (if you see this, you've got it beat) now create a new user signing into your Gmail and Samsung accounts (if you don't have one, create a new account) once you're done with that it will take you to the home screen, pull down the notification bar and go into settings (notice since you're on an added user you can't factory reset the device) find "Users", and then switch back to the owner profile, it then tells you that you still need to set up the tablet to continue. Once i clicked okay it now let me pull down the notification bar to access settings, but this time you're on the owners account so you can factory reset it, go to "Back up and Reset" and then go ahead and factory reset it again. If done correctly the FRP will no longer be on the tablet. I know this probably sounds extremely complex so if you have any questions feel free to message me and Ill give you my email and phone number and ill help walk you through it
The Following 2 Users Say Thank You to abufares For This Useful Post:
Old 05-09-2017, 08:44   #20 (permalink)
Feiselski's Avatar
Member: 2583091
Thanks Meter: 281
Hello Guys
Thanks for sharing Abufaris, The Xda dude's solution is the real deal! No sboot is needed since most of them don't work.
After switch to owner, make sure you pull down the notification bar while the screen is locked because notification bar doesn't work after screen lock is unlocked.
Old 06-14-2017, 14:46   #21 (permalink)
Member: 2330405
Sonork: 100.1661964
Thanks Meter: 33
Originally Posted by abufares View Post
FOUND THIS ON XDA
this one worked oky... thanks bro
Old 08-30-2017, 09:26   #22 (permalink)
Member: 1242652
Sonork: mdobrais
Thanks Meter: 8
https://www.youtube.com/watch?v=Ovpr9iZ1HNg
if your tab lcd is not working after restart-don't worry-pres unlock frp-then write the lattest sw and all done
Old 09-12-2017, 10:33   #23 (permalink)
Member: 84456
Thanks Meter: 6
[QUOTE=vidy25;12546295]this one worked oky... thanks bro[/QUOTE
No works for me. I've the same problem and try this solution. After power down the router , the sreen shows a network poblem and back to terms and conditions screen. I try a lot of times, making wipe data every time, and giving one or more seconds of time for disconect the router, and nothing
Old 10-20-2017, 00:30   #24 (permalink)
Crazy Poster
Member: 848549
Thanks Meter: 9
[QUOTE=wildjoker;12682435]
yes this is a problem with 7.0 hopefully someone will find a solution soon
Old 10-20-2017, 10:41   #25 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 213
Another t580 frp ok. Flash only boot from COMBINATION_FA60_T580XXU2AQC1_CL10816856_QB1279377 0_REV00_user_mid_noship.tar and reset frp via z3x:
Waiting ADB device... OK
Reading phone info...
Model: SM-T580
Android version: 6.0.1
Product code:
Phone version:
PDA version: T580XXU1APE3
CSC version: T580XEF1APE1
CSC country code: France
CSC sales code: XEF
HW version:
Phone SN: R52H60ESCSV
Chip name: EXYNOS7870
Modem board:
Security patch: 2016-05-01
RF cal date:
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.29.5
Old 10-26-2017, 21:30   #26 (permalink)
Crazy Poster
Member: 848549
Thanks Meter: 9
Downgrade to T580UEU2APL4 this worked for me
The Following User Says Thank You to abufares For This Useful Post:
Old 11-01-2017, 06:51   #27 (permalink)
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 956
Anyone get problem with T580 tablet to enter download mode.
I have one come for frp, not enter download mode by key combination, not even with jig, and try with z3x to reboot to flash its always start to normal mode.
Volume keys and home key work properly and it can enter to recovery withot probem. Tablet is new.
Fw version Nougat T580XXU2BQE7.
Old 11-01-2017, 12:32   #28 (permalink)
xheti's Avatar
Member: 209400
Thanks Meter: 62
thx bro abufares Downgrade to T580UEU2APL4 this worked for me too
Old 11-28-2017, 20:50   #29 (permalink)
Member: 1216263
Thanks Meter: 119
What do we do after going back to T580UEU2APL4 ?
I flash boot from combination file and then reset FRP but then nothing happens, the same setup screen again.
Old 12-02-2017, 19:43   #30 (permalink)
Member: 642083
Thanks Meter: 4
ok asi como a mi me toco aprender un poco de ingles, ahora ustedes aprendan un poco de espaņol. Aqui esta la solucion para la SM-T585 7.0 version. el video muestra el modelo T585 y con octoplus, pero yo lo hice para una SM-T580 y con la Z3X escogiendo el modelo exacto.
listo, ready to go.
https://www.youtube.com/watch?v=bIakX0gxkYQ
enjoy it. al menos dar gracias ok.
After a couple of days of work, I did it.
The Following User Says Thank You to randolfotecnico For This Useful Post:
Page generated in 0.42300 seconds with 7 queries
