Old 10-26-2018, 16:53   #61 (permalink)
Member: 2613252
Thanks Meter: 859
Originally Posted by qtouch View Post
So I flashed it with COMBINATION_FA60_T580XXU4ARJ1 for FRP but now I cant find the right firmware to restore it ...
Can some one point me out.
hello, having done the flash of the combination t580 binary 4 you can only flash the binary 4 firmware and you can not do the flash of a frimware that has a lower binary in this case the binary 3, you can also find it on sammobile
Version Android 7.0
Changelist 13839138
Build date Thu, 20 Sep 2018 07:21:41 +0000
Security Patch Level 2018-10-01
Product code
PDA T580XXS4BRI1
Then when you choose the firmware for t580 binary 4 you choose the according to the firmware of the country or region you have installed on your tablet
Old 10-30-2018, 18:01   #62 (permalink)
Member: 465404
Thanks Meter: 5
https://samsung-firmware.org/fr/amp/.../T580OXA4BRI1/
Old 11-18-2018, 09:19   #63 (permalink)
unlock_allgsm's Avatar
Member: 1678945
Sonork: 100.1620753
Thanks Meter: 101
SM-T580 U4 FRP reset how to ?
hi to all any way to bypass frp T580 U4
Itry with combination not succes
how to solve any idea?
thanks in advance
Old 11-18-2018, 09:23   #64 (permalink)
Member: 1254228
Thanks Meter: 59
thanks in advance
contact me on whats app +923016665007
Old 11-21-2018, 09:28   #65 (permalink)
Member: 666861
Thanks Meter: 18
Tab t580 unable get download mode
Tab t580f unable to get download mode. It is protected by software.button combination not work. Any one have solution for this problem.
Old 11-21-2018, 10:56   #66 (permalink)
Member: 2430631
Thanks Meter: 23
Or buy it
Sent from my WAS-LX1 using Tapatalk
Old 11-21-2018, 12:13   #67 (permalink)
Member: 666861
Thanks Meter: 18
Originally Posted by mkgunner View Post
Or buy it
thanks for your reply
Old 11-21-2018, 12:31   #68 (permalink)
Member: 2430631
Thanks Meter: 23
np
Old 11-22-2018, 04:27   #69 (permalink)
Member: 2148129
Thanks Meter: 37
I can remove any FRP or React in just 30 sec. No hassle, no firmware, no boots or combos. Just plug and play. Totally remote. PM me of anyone need support. Also can repair any CPID imei like N9, S9 same day 15 to 30 min.
Old 11-25-2018, 14:33   #70 (permalink)
allali's Avatar
Member: 573588
Thanks Meter: 32
I have the same problem, did you solve yours?
Old 11-25-2018, 20:02   #71 (permalink)
Member: 63646
Sonork: 1670920:45069
Thanks Meter: 21
Can you remove FRP lock from my T580 7.0 U3 ?
Old 11-26-2018, 08:16   #72 (permalink)
Feiselski's Avatar
Member: 2583091
Thanks Meter: 281
This is a tested solution for all versions 7.0, 7.1.1, on binary 2,3,4
If your tablet is on binary 3
1.Flash binary 3 combination
2. Flash ONLY system from BINARY 2 stock firmware
3. After that it will automatically bypass the frp screen then go to settings and reset the phone.
4. Now frp is completely removed, but you have to flash full binary 3 firmware because the screen inverts sometimes.
IF your tablet is binary 4 you have to do the same thing but this time you have to flash system from binary 3.
Tested on SM-T580 AND SM-T585!
The Following 2 Users Say Thank You to Feiselski For This Useful Post:
Old 11-29-2018, 10:50   #73 (permalink)
Member: 63646
Thanks Meter: 21
This is not working for me, Samsung was on bin3 (u3) tried to flash bin3 combination
this gives error during flasing: File analysis... OK
Total file size: 0x3EC975B0 (1004 Mb)
Searching USB Flash interface... COM11 detected
Setup connection... OK
Set PIT file... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending param.bin... OK
Sending cm.bin... OK
Sending boot.img... error timeout
Done with Samsung Tool PRO v.34.3
on display from T580 it shows : FRP is enabled. ignore PIT download
FRP is enabled not allow download non-FRP Bootloader binary
I tried this also with U4 version gives same error
Old 11-29-2018, 11:19   #74 (permalink)
Member: 205302
Thanks Meter: 5
SM-T580 Frp Succes T580XXU4CRJ9!!
Procedure:
flash COMBINATION_FA60_T580XXU4ARJ1_CL10816856_QB2011243 6_REV00_user_mid_noship.tar
Octopus box frp by uart.
The Following 2 Users Say Thank You to aditza For This Useful Post:
Old 11-30-2018, 19:10   #75 (permalink)
Member: 63646
Thanks Meter: 21
No one with Z3X box ?
Page generated in 0.45547 seconds with 7 queries
