12-03-2018, 11:40 | #76 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Brussels - Belgium
Member: 236097 Status: Offline Thanks Meter: 29 | I confirm this solution worked for me with T580 u4 SM-T580 Frp Succes T580XXU4CRJ9!! Procedure: flash COMBINATION_FA60_T580XXU4ARJ1_CL10816856_QB2011243 6_REV00_user_mid_noship.tar Octopus box frp by uart. |
The Following User Says Thank You to elassooudi For This Useful Post: |
12-14-2018, 01:17 | #85 (permalink) |
Junior Member Join Date: Sep 2008
Member: 867708 Status: Offline Thanks Meter: 3 | T580 U3 FRP off Done!! Exact way how I did my U3 device FRP OFF: T580 with firmware T580XXU3BRF1 BTU 1. Flash COMBINATION_FA60_T580XXU3ARG1_CL10816856_QB1882831 4_REV00 user_mid_noship tar md5 - let it start, then reboot to download; 2. Flash System_img ONLY from U2 6.0.1 firmware, I used T580XXU2AQA2 BTU - let it start, then reboot to download; 3. Surprise - FRP Lock: OFF; 4. Full flash with U3 firmware and that's it. Release the Kraken Z3X was very helpful in this case. P.S. Sorry for missing dots or "_" instead of dots but - "An error has occurred RadioActive83! You must have 10 posts in order to post links. Your current post count is 2." |
01-19-2019, 15:35 | #86 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 379165 Status: Offline Thanks Meter: 50 | here solution for U4 binary no box need use odin in folder https://www.youtube.com/watch?v=gW1IdBaG6MY |
The Following 5 Users Say Thank You to halaxi For This Useful Post: |
01-24-2019, 05:06 | #87 (permalink) |
Junior Member Join Date: Jan 2016 Location: missouri, USA
Member: 2515120 Status: Offline Thanks Meter: 9 | If your on 6.0 just add new user ..finish setting up new user profile then go back to original user and you can oem unlock in developer options ...then just factory reset....7.0 or newer u can flash combination file ...then remove userdata from the stock firmware ..it should boot straight to touchwiz launcher screen. if not you can use smart device flow to copy google account via bluetooth to the device. (google search: xda smart device flow frp) |
01-28-2019, 16:25 | #88 (permalink) |
Freak Poster Join Date: Jul 2004 Location: romania Age: 56
Member: 74915 Status: Offline Sonork: no Thanks Meter: 22 | Not work [QUOTE=here solution for U4 binary no box need use odin in folder https://www.youtube.com/watch?v=gW1IdBaG6MY."[/QUOTE] hy, for T585XXS4BRI1_T585OXA4BRI1_DBT firmware not work need flash tab with android 8.1? T580XXU4CRJ9_T580XEF4CRJ9 tks Last edited by akaygsm; 01-28-2019 at 16:35. |
01-28-2019, 16:38 | #89 (permalink) | |
Member: 74915 Status: Offline Sonork: no Thanks Meter: 22 | sorry wrong quote... Quote:
need flash tab with android 8.1? T580XXU4CRJ9_T580XEF4CRJ9 tks | |
02-11-2019, 15:57 | #90 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | t580 u4 removed from 2 tablets Platform: Samsung Android Selected port: COM6 Selected model: SM-T580 Operation: Reset FRP - UART EMMC Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.7.7.4 Software version. |
