06-07-2016, 09:45 | #1 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Ethiopia
Member: 1881881 Status: Offline Thanks Meter: 44 | smg531F UNLOCK GOOGLE ACTIVATION ERROR PLEASE HELP Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 25.5 Searching Samsung USB Flash Interface... detected COM17 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.5 |
06-07-2016, 10:48 | #3 (permalink) |
Insane Poster Join Date: Jan 2015
Member: 2321119 Status: Offline Thanks Meter: 119 | flash this file in BL then reset with box Dev-Host - FRP_G531F_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service only thanks button T |
06-07-2016, 17:39 | #5 (permalink) | |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Quote:
If u have failed all method See my post Sent from my iPhone using Tapatalk | |
